Author Topic: 1969 390 IP head questions  (Read 5297 times)
gordonr390
« on: January 19, 2016, 08:28:43 PM »
After determining a rusted no#7 intake valve causing 80% leak down. I pulled the heads this past weekend and decided to clean them up and box-em. I found a another matching set of C8AE-H castings from a head porter friend as I'm wanting to keep this motor appearing accurate but would like to make a little more power. So he found a set of custom Ferrea 26* 2.095 intakes locally cheap. Installed, cut the seat to 45* and cut the bowl then blended. Now were setting at a 90% choke (better than the 93.2% in stock config with the 2.030's) and these are the numbers so far @28".
.100   74
.200   167
.300   217
.400   222
.500   246
.550   256
Haven't tackled the exhaust yet. But I see major issues with 3 of the 4 ports having heat risers exiting to the intake and killing exhaust port speed. Talked with Alex at Alex's Parts today and he commented that some old timers had poured aluminum in to seal up the heat riser exits and then blended the ports. I was interested in finding out if anyone has performed this mod and how it worked out?
gordonr390
Re: 1969 390 IP head questions
« Reply #2 on: January 20, 2016, 10:00:49 AM »
I found this video on youtube from a guy thats apparently has been doing the mod for a long time.   https://youtu.be/k6j1JuccvhQ
     I'm leaning on the Idea of filling the exhaust heat riser ports on 1-4-5-8 only and leaving ports 2-7 alone. Any thoughts? This car is a weekend driver with 90k on it.
I came across another stock manifold and would like to have it extrude honed.  Can enough material be removed to get close to the port entrance sizing of the head? Any recommends on a service company that can do the job?
   I'm hoping to get some time this weekend to make up some fixtures for my flow bench and really get going on this project. All of my fixtures are for Harleys.  :-[
gordonr390
« Reply #3 on: January 20, 2016, 07:56:37 PM »
     "I'm leaning on the Idea of filling the exhaust heat riser ports on 1-4-5-8 only and leaving ports 2-7 alone". Any thoughts? This car is a weekend driver with 90k on it.
(I don't know what was going through my head but It seems I'm really having a hard time remembering this engine is water cooled. I appreciate and respect you all for not busting me about my dumb mistake).
« Reply #4 on: January 21, 2016, 12:04:12 AM »
The heads heat riser ports only exist on cylinders #2 and #7.  So looking at the exhaust side of the head, the 2nd port from the right on each head.
