Author Topic: C6 pan gasket  (Read 7620 times)
IDOIT4SPEED
C6 pan gasket
« on: January 10, 2016, 10:59:44 AM »
pan gasket is leaking on my hauler, looks like the fluid is seeping through the gasket. any preference  on gaskets? sealer yes/no? has a cork gasket now.
rcodecj
Re: C6 pan gasket
« Reply #1 on: January 10, 2016, 11:33:00 AM »
I have used  the Moroso one on 3 cars and I like it, reusable too.
It says it's not made for a stamped steel factory type pan but I've used it on two factory pans with good results.
http://www.summitracing.com/parts/mor-93108/overview/
Re: C6 pan gasket
« Reply #2 on: January 10, 2016, 12:08:03 PM »
Thanks rcodecj for that link, I've never tried that gasket, I might have to check it out. Most of my vehicles have a C6 so I get some pan gasket practice. I'm very lucky to have an excellent professional mechanic, BradFord, as a good friend and he has shown me it's key to have a nice flat pan surface for the stamped steel pans. The area around the pan holes tends to "dimple" and he has shown me how to take a hammer and flatten those spots back to flat. He is an expert at it and I will admit to letting him apply his skill to some pans that are well used. But it's really just basic metal working. I just use the generic cork/rubber gaskets with no sealer. The thin pan gaskets will "saturate" with ATF eventually, but being almost an inch wide it takes quite a while as long as that pan surface is flat. I tried the Fel Pro rubber C6 pan gaskets long ago and they leaked something terrible with the stamped steel pans. One other thing to watch for is not to over tighten the pan bolts. If the cork/rubber gaskets really start deforming and squeezing out they will leak and it just ends up "dimpling" those pan bolt holes. A lot of the newer vehicles have a pan gasket that has metal reinforcement rings around the bolt holes and they really help to keep from over tightening the bolts, but I haven't seen any of those available for a C6.
Re: C6 pan gasket
« Reply #3 on: January 10, 2016, 03:15:24 PM »
+2 on the moreso gasket.  I lovem.
Be aware tho, it's like 1/4 inch thick so if your bolts are a little short you might need to seek out longer ones (or studs, which I prefer).
JamesonRacing
Re: C6 pan gasket
« Reply #4 on: January 11, 2016, 04:36:07 PM »
I'm using one of these on my current build...haven't installed it yet, but I have high hopes!
http://www.lubelocker.com/transmissions.html
FirstEliminator
Re: C6 pan gasket
« Reply #5 on: January 15, 2016, 10:55:32 AM »
    Cork works great. The trick is CLEAN and DRY. Tighten the pan bolts, then tighten them again.
   I own a transmission shop and there are very few transmissions that I prefer to use something other than cork. The other popular option is Duroprene. It's thinner than cork. The one benefit is it's a little more resistant to having a bit of oil on it during installation. Some trans you just can't reinstall the pan fast enough as a trail of oil forms down the pan rail of the case.
   That Moroso gasket looks nice. Not too pricey, especially since you only need to buy it once. It's like what the factory calls "elastomeric pan gasket". Domestics have been using this since the late 90's. Ford's 4R100, AODE, AX4N, CD4E 5R55w,s,n all use it. They carried the 5R55e up til 07-08 and it stilled used cork. GM and Chrysler also use this style pan gasket on some of their units.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
IDOIT4SPEED
Re: C6 pan gasket
« Reply #6 on: January 15, 2016, 08:38:09 PM »
 had good luck with the Moroso blue valve cover gaskets, pan gasket looks like the same thing. have one on order. thanks.
