Author Topic: 360 Cam?  (Read 5124 times)
jackrod4392
360 Cam?
« on: December 09, 2015, 06:09:44 PM »
I have a 72 360 in my f100 and am wondering about the lacking of power? I am putting a four barrel on it. I am also going to put a good cam and lifters. What cam would be good for a 360 with 3.25 gears and a c6 behind it. I want good power but not where I can't tow. Thanks in advanced. :D
bluef100fe
Re: 360 Cam?
« Reply #1 on: December 09, 2015, 11:04:30 PM »
I ran a small a small crane hydraulic in mine for years as a daily driver it was all done by 5000 rpm but it is what it was I think it was 194/204 @0.050 and 485/510 lift. Just a little bigger than a stock Fe cam. I also ran a comp solid flat tappet but it was a lot bigger and ran fine on the street with a loose converter but I wouldn't recommend it without valve train upgrades.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
Re: 360 Cam?
« Reply #2 on: December 10, 2015, 05:58:20 AM »
I've been sitting on the fence about answering this post....
Finally decided to answer and say that I think I would just degree the factory cam, put a nice timing set on it, and be done with it.  (If the cam is not worn, that is...)
« Last Edit: December 10, 2015, 08:21:10 AM by blykins »
Re: 360 Cam?
« Reply #3 on: December 10, 2015, 12:49:57 PM »
You have to keep in mind that it only has about 8.5 to 1 compression.
The smaller 4V intakes and 600ish Holley and a modest RV cam will give it a bit more giddy up
and still be able to lug the loads up the hills.
A set of pipes will give you a tad more grunt also.
And they are relatively cheap in FE world. ;)
Some ads to look at.
http://www.crower.com/camshafts/ford-332-428-compu-pro-hydraulic-cam-246-hdp.html
http://www.summitracing.com/int/parts/big-12540flt/overview/year/1972/make/ford/model/f-100-pickup
jackrod4392
Re: 360 Cam?
« Reply #4 on: December 13, 2015, 12:41:14 PM »
Thanks for the help  ;D I don't know what im going with but it all certainly helps.
