Author Topic: Crank Main Bolts  (Read 25516 times)
rcodecj
Re: Crank Main Bolts
« Reply #15 on: March 31, 2012, 09:02:02 AM »
I'm accuring parts for my 445 build and ARP Main Cab Bolts are in the box to take to the builder.  What should the torque spec be if using ARP's assembly lube?  I have not broken the seal on the box, is the spec inside? Thanks. ww
It should have instructions in the box. If not try putting your kit number into this link:
http://arpinstructions.com/index2.php?src=arp-bolts
4twennyAint
« Reply #16 on: April 03, 2012, 08:27:38 PM »
My ARP stuff usually came with a chart, showing the torque if using moly lube and also another value for oil.  Since I just moved I've got it all packed away.   Maybe they have it on-line at the ARP site.  The builder probably will have one of these charts also.
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
