Author Topic: One wire alternator and cut off switch doesn't work.  (Read 5505 times)
57 lima bean
« on: October 26, 2015, 07:17:54 PM »
I read to install the alternator wire to the positive(battery)side of the switch,but that makes no sense as this would keep the field hot.Have I been licking to many toads?
JERICOGTX
Re: One wire alternator and cut off switch doesn't work.
« Reply #1 on: October 26, 2015, 08:18:14 PM »
I had to run mine through a relay. The one wire was drawing power when it wasn't running? After the relay I never had a problem.
fairlanegt427
« Reply #2 on: October 27, 2015, 09:05:41 AM »
put the positive battery cable (that runs to starter relay) and one wire alt both  on one post of kill switch,  the other post put your battery positive post wire to it.
« Reply #3 on: October 27, 2015, 10:08:37 PM »
If its really a one wire alternator, it should have an internal voltage regulator that will cycle the field coil in the alternator on and off as required.  So, connecting the wire to an ignition-hot circuit would be correct.
57 lima bean
« Reply #4 on: October 28, 2015, 08:16:04 AM »
Gosh,maybe its not a one wire....Counted twice.LOL.Please pick the right diagram.
https://www.google.com/search?q=one+wire+alternator+kill+switch&espv=2&biw=1008&bih=635&tbm=isch&tbo=u&source=univ&sa=X&ved=0CEAQsARqFQoTCLCRgZ-f5cgCFUrmJgodGGcIvw
Maybe it just doesn't matter as the car is to slow to require it.
« Last Edit: October 28, 2015, 10:29:52 PM by 57 lima bean »
57 lima bean
« Reply #5 on: November 03, 2015, 10:23:32 AM »
You had to have had a bum diode for this to happen Jeff.I do have all winter to get things wheeled in.See ya in a couple of weeks.
fairlanegt427.......Thanks.That worked.
« Last Edit: November 09, 2015, 09:11:21 AM by 57 lima bean »
