Author Topic: pulleys  (Read 13224 times)
Re: pulleys
« Reply #15 on: October 25, 2015, 08:49:37 PM »
It's very annoying I will get to the bottom of it and fill ya in. Try that pulley though
BigBlockFE
Re: pulleys
« Reply #16 on: October 26, 2015, 12:09:42 AM »
Kirkham motorsports sells billet pullies for the FE...
stangbuilder
Re: pulleys
« Reply #17 on: October 27, 2015, 03:05:34 PM »
Ok i just ordered the 1-1 W/P pulley..Will update results when i get it changed out. I live in L/A it been hot about 80-85 so it will be good test
Tim R
stangbuilder
Re: pulleys
« Reply #18 on: October 29, 2015, 10:50:47 PM »
Update on change. Went to a 1-1 set up dropped temp by about 15 degrees. It was about 80 today in L/A. Got up to 200 pulling a hill.So after everything said and done it did help. Seems that its going to run 190-200. Witch is fine but i really think this combo on the street needs to run the water pump at 10% over driven.Being a all alum piece its best to run them a little hot.. Its still marginal at best.
                          Tim R
Re: pulleys
« Reply #19 on: November 01, 2015, 09:04:50 PM »
Good to hear you think you got it
