Author Topic: fuel pressure problem  (Read 3982 times)
fairlanegt427
« on: October 11, 2015, 09:03:49 AM »
I have a holley red fuel pump and a holley regulator,  I cant keep the pressure regulated,  I replaced diaphragm and put in the low pressure (red spring)  I turned on pump and set pressure to 6 psi,  it stayed their for about 5 seconds and then just steadily climbs up and I cant control it.   I do not have a return line on this car it never needed one.  the regulator always did a good job.  do the internal check ball and spring on these regulators go bad?  its never happened to me before so I have been scratching my head on this one.  that being said I could use some answers on this and also some pressure regulator recommendations.
fastback 427
Re: fuel pressure problem
« Reply #1 on: October 11, 2015, 10:06:29 AM »
Throw the "free" holley regulator in the garbage. Buy an aeromotive or quick fuel. Problem solved.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
