Author Topic: 452 cu. in IR intake FE  (Read 7942 times)
pkm123
« on: October 05, 2015, 08:06:44 PM »
Built this engine years ago, but recently completed induction upgrade.
Block: Shelby aluminium
Crank: 428 cast iron internal balance
Rods: Eagle
Pistons: JE
Heads: Edelbrock Stage I  2.25, 1.75 with 220/520 springs
           Flow: 292 at 0.600 intake
Cam: Comp Cams 248/254 .64/.64 SR on 110 LCA, 107 ICA
Rockers: Erson
Intake: Blue Thunder Independent Runner
Throttle bodies: Ebay OBX (Chinese) 50 mm
Injectors: Deka 60 lb.
Computer: Megasquirt MS3
ignition: MSD controlled by computer
Car is 1968 Mustang fastback
Trans: t56 magnum
Rear: Ford 9" 3.73 Locker
The engine made 450 whp and 495 lb ft on the chassis dyno.
Estimated 18% drivetrain loss is 550 hp / 600 lb.ft.
« Last Edit: October 05, 2015, 08:21:09 PM by pkm123 »
pkm123
Re: 452 cu. in IR intake FE
« Reply #1 on: October 05, 2015, 08:21:49 PM »
pics
« Last Edit: October 05, 2015, 08:24:43 PM by pkm123 »
fairlanegt427
« Reply #2 on: October 09, 2015, 04:58:10 PM »
what is compression?   also that's a nice injection setup you have on their.  I can only guess how much time you have into that.  but time well spent,  it looks really good
pkm123
« Reply #3 on: October 11, 2015, 11:46:03 AM »
Compression is 10.8
