Author Topic: Behind The Times; Discovered A New Technique  (Read 7272 times)
chris401
« on: October 01, 2015, 11:20:09 PM »
Is this what some of the pro's do these days?
Re: Behind The Times; Discovered A New Technique
« Reply #1 on: October 01, 2015, 11:33:39 PM »
Whoever did it must not realize the thrust surface of the crank isn't there.
« Last Edit: October 01, 2015, 11:42:37 PM by thatdarncat »
« Reply #2 on: October 02, 2015, 04:14:24 AM »
How long has that been running that way?
Lenz
« Reply #3 on: October 02, 2015, 07:16:45 AM »
Every once in awhile someone comes along who helps a non-pro like myself understand, you aren't as much a rookie builder as you may think.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
« Reply #4 on: October 02, 2015, 09:53:22 AM »
Isn't the thrust surface on a Chevrolet crank on the #5 main?  If so it would seem like a Chevy engine builder got his hands on that FE, and made a serious error...
chris401
« Reply #5 on: October 02, 2015, 09:55:31 AM »
I got it on a trade without the rotating assembly. Don't know how long it ran with these bearings but the block is a worn .030 over 352.
chris401
« Reply #6 on: October 02, 2015, 10:11:37 AM »
I was almost 13 when I learned how to use a file and Emory cloth. Dad turned his back and I beat out the 360's thrust bearing with a hammer.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #7 on: October 02, 2015, 10:22:36 AM »
That and the rear main seal should be off set 3/8" and never lined up with the parting line of the cap/ block. LOL
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #8 on: October 02, 2015, 10:23:45 AM »
Yes, it does as Jay said look like a 1st gen. SBC bearing. Wow, and here I thought Jasper Engines, the bane of rebuilders, was on the loose again!  ;)
410ranchero
« Reply #9 on: October 02, 2015, 10:47:31 AM »
Nut to mention that's the top bearing in the cap. No way it ran like that. The oil singer on the crank has no where to go.
