Author Topic: Cylinder Distortion  (Read 14975 times)
Autoholic
Cylinder Distortion
« on: September 16, 2015, 08:22:46 PM »
I came across this video and it made me wonder, how common is it for engine builders to hone the cylinders without being under load?
https://www.youtube.com/watch?v=6cLjdr2GSwU
~Joe
Re: Cylinder Distortion
« Reply #1 on: September 16, 2015, 08:37:45 PM »
saw that vid some years ago and posted it to this and other Ford blogs. Most rebuilders (if not all) do not use plates, period. Even some alleged race shops don't! A quality shop will and will even borrow plates back and forth amongst other shops as, of course, they are engine make specific.
My take is this: long ago, engine blocks for 50's-60's Caddies, Olds, Pontiacs, Fords were massive pieces of cast iron as weight was not a consideration. Man, I can assure you lifting a dressed Buick of the era required arms of steel even with a good hydraulic engine lift!
A good by-product was massively thick cylinders. Later, all the USA makers started to pay attention to weight and started thin-wall casting techniques, lead by Ford. But as a result, FE's, Clevelands, Windsors and to a much lesser extent 429-460 engines ended up with some pretty thin walls. The thinner the wall the more likely a deck plate is needed. The vid is quite instructive as to what happens when a plate isn't used. Any top notch shop uses them to assure maximum ring seal and long ring/piston life.
« Last Edit: September 16, 2015, 08:58:07 PM by machoneman »
Qikbbstang
« Reply #2 on: September 16, 2015, 08:50:23 PM »
I took an auto machine shop class at a local community college. A yahoo had a 400 cu in SBC in his air-boat. He added an additional tug when doing his head bolts. So much so that when he pulled the motor apart after running it there was a perfect five point wear pattern in the walls where the rings failed to touch and scoring where they did.
I bolted a head on a 427 block and mike'd it with and without a head on and then bought a deck plate since no local shops had them. The bore distortion shocked me.
Autoholic
« Reply #3 on: September 16, 2015, 09:04:47 PM »
That is a little troublesome then, if most engine builders do not use a deck plate. The video was very telling, you could easily see the distortion and sleeves are the most vulnerable to distortion due to relatively thin walls. When people will overbore a block a few thousands because the cylinders are a tad out of shape, makes you wonder how much cylinder wear is caused by not using a deck plate the first time.
Below is a link to an episode of How It's Made Dream Cars, covering the Falcon F7. It shows Lingenfelter's process for building the engine and you'll notice that they didn't use a deck plate. They have an awesome, stupid expensive CNC machine to make sure the block is perfect, but they don't bother with cylinder distortion due to cylinder head loading, on an aluminum engine block. I would imagine that aluminum blocks distort the most.
http://www.projectfreetv.sx/link/2349924
I could see some arguing "well, it's just 0.001-0.002" of distortion". The piston's bore and the gap of piston rings is measured in thousandths however, so the tolerance at max is 1 thousandth of an inch. I wonder how bad cylinder distortion of 0.001" effects ring flutter at high RPM?  Maybe Barry can chime in on this subject, for performance engines, what is the tolerance here? Half a thousandth?
« Last Edit: September 16, 2015, 09:13:18 PM by Autoholic »
~Joe
« Reply #4 on: September 17, 2015, 04:52:23 AM »
We always use torque plates.  If I'm working on something that we don't have plates for, I will borrow or buy it.
Some blocks are worse than others for going out of round when the plate is bolted on, but remember that every .001" of cylinder wall diameter can affect your ring gap by up to .003".  It also depends on the location of the fasteners and how far down in the deck they engage the threads.
This is why you would get varying degrees of performance from the same car/engine from the OEM back in the day.   When engines are thrown together in a production setting without verifying cam timing, piston clearance, deck height, etc., then you get some that are dogs and some that run like scalded cats.
« Reply #5 on: September 17, 2015, 07:32:11 AM »
Every FE we build has two torque plates mounted - one on each side - before it gets honed.
« Reply #6 on: September 17, 2015, 09:20:39 AM »
I'm pretty sure I've also heard or read that some shops will also warm the block before the final hone.  I'll lightly ball hone a cylinder for fresh rings if there's no damage and it's just an annual fresh up.  But if there's any question, it goes to a shop with a plate.  I'd not a Barry or Brent but I have learned over the years that cylinder finish and prep, deck finish and prep and head valve work are the top three areas you best get right.  Mistakes or shortcuts in those areas will really hurt the final product.
HolmanMoodyStroppeGang
Sealing trick history or evolution
« Reply #7 on: September 17, 2015, 10:58:12 AM »
For fun and to look back from our circle of pals, I have some old thoughts from the very old guys who mentored many of us over the decades.  I have always loved to see how old tricks are new, what new is sometimes old, and how engines get refined to get more and more power from the same parts.
When we built say, 4 identical race 390s, or 428s, or 427s, and these were blueprinted to the 0001 and very precise, head c.c's with.1 and every piece massaged, it was always interesting how the final dyno numbers,corrected for weather, water grains,  the baro and so on, we often had one or two that had that mysterious 'tick' more oomph.
Presuming this, the best piece went to the best Driver who had the best shot at the title or championship.
So I just ponder the below and more.
Class racing with rigid tear down rules play a part, so does guys who always push the envelope to win but not break the rules, and of course, guys who break a rule maybe, or do things that are in a gray area  or gap in rules.
In the 60s, the old guys would quietly share with team members, how T based race engines, in-line 4's using trick OFFY MILLER FRONTY or other heads, and FORD blocks and welded stroker or hand cranked cranks, rods and pistolero's, might, or often, ran better not newly bored and honed, not at all, but with clean bores that had been allowed to break in a long while
Remember, today, as we did 40 years ago, the torque plates and heads done and finish lapped on a torque plate too, and so on, results in a Dyno break in where the blow by gauge shows night seal fast, as opposed to 50-60's production engines that required maybe 1,000 miles to 'break in'.  You owners manual had time tested procedures to break in the engine, and this light throttle time, often different oil, and all the directives to'not jack rabbit start', or maintain the same RPM, or load the mill hard, etc, was by design
An engine settles in, and basically fits itself as it wears and burnishes off high spots, the RMS or finish of many parts, gets refined or smoother, and the parts mate, rings rotate and get shiny, as the marry or honey moon, lol, with the specific bore they live in, seats conform the valve faces, guides hone in, loosen a tenth or two and so on
So long ago, the real slick engine guys knew that a reciprocating assembly, that was broken in and fit under load, had a slight edge after a series of races, or after some time.
Some old guys around us called this 'loosening up', others, 'getting 'run in', or, letting the entire assembly 'get happy'
So as a hot rod engine got raced, you tore her down and read the parts closer and closer.
And parts reading between races is huge, it can yield hints to more power or a new path, it can give clues to wear, an impending failure issue, hardness incompatibility, what parts are in harmony hardness wise, what part is being sacrificed or wearing faster but acceptably, and when you want to change in a new part to maintain power and life, often.
So when I was real young, surrounded by racers,race cars,engine, blower, chassis and other shops, you'd hear a lot of trick guys quietly say that they believed that their 'seasoned' block made more power or was quicker for reasons that were correct, or obvious
I vaguely recall some top builders around us, honing their blocks upside down with the heads on in the early 60s, and talk that others had tried this in the 50s and before
Why?    In the 30s and 40s, some of the fastest piston engines did NOT have removable heads.
Many cutting edge race engines for airplanes in the 20s-30s and 40s were very trick and ahead of their time. Many of these tricks, trickled down to Hot Rods
So reducing cylinder distortion for initial power was a concept or trick that evolved quietly. Not in magazines, not in the aftermarket for some time
FORD had engineers who pondered this in the 60s because several of those engineers came out West, and were maybe a generation older than some of us, and It was cool to hear the debates and pros and cons play out in our FORD MERC race engine cells
The for EEE guys had bosses who won in the 50s, and they trusted what won and worked for them, so head plates had to be proved and tested and many good old class Drag Racers building at home played a nice part.
FORD guys, in Detroit, by the mid 60s, moonlighted in race shops close by. Head plates were made for example, by EE guys over at DOUG NASH in the 60s, tried, proved then adopted
My co builder on many fast mills, DN, spend months making them so guys like DYNO DON and others could quietly try them and maybe gain some hindeths(maybe a 9.30 might shave a .01 or 2 sometimes
So things evolved but for sure, around us, many very accomplished engine men, who had won the huge races for FORD and others, and who had their hands on a bunch of major victories and trophies, titles and record, did not buy in to the need whole heartedly
And if you work on the blown and injected stuff we all have around this swamp, shucks, check into it.....decades after decades of blown fuel, alky,gas cars, injected fuel, alky and gas cars flat fly and do not get finished honed with a plate
Very few Kieth Black HEMI blocks for example, got a finish plate hone of many years if blown, injected, or pushed way past the carb power numbers, not the KB 1's,2's3's,4's, 5's...LOL or the KB 10 we have in one 5 second car right now. Same with hundreds of Brad Anderson blocks, same with probably all the JP 1 PISANO blocks we saw, same with so many Allen Johnson blocks today so this is a relevant observation to some builders
at 400 hp, plates and a seasoned block will hand you 2-3% free power maybe, right from the break in, or soon. BUT< after an engine runs and runs, it also will settle in, and pick up some power naturally, without plates to our observations and durability testing
Carbs up to a 1000 HP? Of course, why?
A Pro Stock engine can NOT waste a lot of time doing break in passes.  Your goal is max power, off the dyno, fresh and fit, drop it in and chop away at a record or win
But if you step the HP per CUBE up above , lets say Pro Stock level cylinder pressures and RPM, load, and time in use, passes before freshening, once you go injected alky, injected nitro, blown gas, blown alky, then blown fuel, the seal is more forced by boost and cylinder pressures, and the BMEP demanded, right?  You go logically up the HP/cube ladder and it seems, the need for plates and other similar tricks is 'nice' but no big deal. Often, a ductile interlocking sleeve with super thick walls, is part of the reason, but when you force feed a chamber, and a conformable stainless top ring, including the old 031 DYKES we ran and still use sometimes, the power level,3 hp/cube( say injected alky,good gas)  to  (Nostalgia heritage levels, one fuel pump, only 1 mag,small 6-71 blower, overdrive limit rule)10,11,12 Horses per cube, nobody uses a plate to hone.  Its rare.    For NHRA Pro series stuff, the 500 CID 14-71 twin arc welding magneto,  max Godzilla fuel pump land rocket mutha's, flirting with around 10,000 horsey's.....no plates between rounds....
So why?
The sleeves are used, they broke in on the burnout if not the warm up in the pits, the re fit and settled.  In max form, around 20 HP per cube, between rounds what do you do?  Well, there is the sleeve and bore, you read it close.  You see burnishing and wear on the thrust axis, and you see a lot.   If you dial bore gage it to the 0001, like so many have done 50 years or so, it ain't all perfect round,,,,LOL
It will get rounder when the heads get torqued, but you use a flex hone.  Why?  If follows the minor distortion, if any, And re finishes the bore where and how it is compressing, elongating under load, and changing after it warms up then sees piston melting hell fire in the chambers and exhaust
So, on pump gas , small inches,one carb,heavy car,tall gear, small cam,mufflers and an air cleaner, car A racing car B, identical builds to the washer, my money is on the head plate honed car for maybe a few bumpers when brand new( bumper lengths through the eyes/traps/at the 1320 mark)
On  a Pro Stock? Much bigger deal probably, maybe half a fender
But as the HP per cube goes up from there, plates are not really the trick of the month and have been tried and not and used and not, over 40 some years, and less of a deal
OK
BARRY is a genius builder and the 2 plates is how smart guys distort the casting evenly on both sides, now, serious comp racers and super stockers, even us in the 70s, like Dyno's 351 C's,(flexy blocks)  super trick builds bolt the motor mounts on, water pump, front cover, oil pump, freeze plugs in, and then plump the block to run water at 180 degrees or 210, wherever the mill lives in the race
ALSO
For decades, brand new iron blocks, and some alloy, go into a cup engine or others, only after the casting is stress relieved to minimize dimension shift. We ll know this but for the new guys, many engine men mount new blocks on a trick vibrating shake table firmly, then vibrate it over a range of frequencies, and modes, for up to a few days in some instances..LOL  for hours in others, to let the block or heads release internal stresses and settle in to where the dimensions remain more stable during use
Heat cycling, hot cold hot cold is big too, so again, a real clean block, raced a while then re-freshened, still can have that tiny edge to some
Brent as always, make a smart, mechanic engineer, pro builder point too
I hate to offend anybody but shucks, I cant count how many engine builds I have read in the past years, that say,,,we plate honed the block, at the machine shop, took it home or to the shop, fit the rings......
Not to bug a soul, we fit the rings with the plates on...for decades.....it only makes sense?
Plates off, then fit the rings?  Well, gap all 16 with no plates, then bolt the plates on and compare....right Brent, 001 distortion due to torque loads,, times Pi, 003 plus real so fit it stressed is our deal too....
FORD Race team tricks
I smiled really wide when Blair kind of clued some guys in on a thing we knew long back
A race FE, fired then shut off in a few minutes on a dyno, with iron block and heads, all super trick, cc'd fussed over and perfect to the 0001, may NOT leak down all even at first. FE's can leak a bit on the end cylinders due to deck and head distortion for a little while but that vanishes pretty fast, as even a really trick FE says..let me break in a bit, or settle in and get comfortable;...LOL....And yup, if you do your entire valve job on a head plate bolted to the head, this above phenomenon diminishes significantly
Now also,,,,,,,,,,some guys do insist on an aluminum head plate, thick, sometimes a sacrificed alloy head that got hurt, why?   An aluminum ported race head can be a lot softer and more flexible than a bitchin surface ground thick BHJ style head plate
So a few super tuner amigos do split those hairs to chase those 2 or 3 ponies in a tight class racing situation
Always fun
I made FROD a torque fixture we called it on a Mill in about 1972 by taking a hurt 427 Tunnel Port head, then boring the 4 holes right through the used head
We had a huge machine shop and tons of capacity and tooling so it was fun
That really lightens a head
We liked these fixtures because the head bolt lengths were correct, and so was the crush rate of the cast iron bosses cast OEM ......
OK, enough old school observations
Only hope is that it helps us all think through more then more ways to win, innovate and do good work
I love the trick new style head plates too, insist on them for anything with a carb.
Now here is my mid flex issue that has been fun for decades. And we had Smokey Yunick as one of many sub contractors on some builds and he pondered this.
If you do not think and engine will settle in and get happy, remember this. Some of our GT40 engines got Dynoed, then raced, then re dynoed. So did some boat race engines, some off road FE's, some stock car FE's.
Remember me explaining our rigid build sheets and tear down sheets, listing the post race dimensions?
I learned something long ago when the observed rotating torque of the cold engine before the Dyno,after the dyno, then after a race is studied.    This is correleated to wearing in many surfaces, super finishing some finer too, and what really changed my thinking was when some race engines came back from a race, and got dynoed and had MORE power
That is worth pondering for some of us and fascinates me sometimes
I enjoy when you guys think out parasitic issues and so on a lot....building a better mouse trap is a cool challenge. Trust me, FORD spent millions on FE's to win and win they did
Blown fuel time for 3 days, pray for a safe race
Adios
PS..You guys are all great, thanks for all that you do
+3 day FORD race this weekend at bakersfield/Famosa
+ Have new Shelby blocks agin if somebody needs help
See ya soon
« Last Edit: September 17, 2015, 05:34:45 PM by HolmanMoodyStroppeGang »
« Reply #8 on: September 17, 2015, 11:38:21 AM »
So... I saw that video I dunno, 8-10 years ago?
It was posted on a diesel forum.  So myself, and several others that happened to have a few 6bt blocks tried that trick (I happened to have a few other inline 6 blocks around and tried them as well).
None of us could get the bore to distort enough to drop something out of it like they did in the video.  I even tried to do it with some large C clamps.  Something so precariously balanced could fall if you touched it wrong, but nothing we did confirmed that it was due to the bore distorting enough.
I encourage you to try on any engine block you may have sitting around.
That said, it seems foolish to build an engine without a fixture.  I can understand tossing an engine together in the back yard, but building an engine from scratch it seems like a no brainer to have the machine shop take care of this.
Autoholic
« Reply #9 on: September 17, 2015, 01:27:53 PM »
What makes more sense, running 200 degree coolant through the block before honing or just putting the block in an oven set at 200 degrees for say a hour before honing? It's interesting to read about the various tricks builders have used to get the best results.
~Joe
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #10 on: September 17, 2015, 10:59:59 PM »
Also feel it's the machine and the guy running it too. I'm sure that plays a part... Very few good machinist left.
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #11 on: September 18, 2015, 06:15:36 AM »
All the Pro Stock teams today hone with circulating hot water (stays hot throughout the honing) and deck plates.
Read this 2005 article that highlights the start of all Pro teams today using hot honing: http://www.enginebuildermag.com/2005/03/has-hot-honing-cooled-off/
« Last Edit: September 18, 2015, 08:27:54 AM by machoneman »
Autoholic
« Reply #12 on: September 18, 2015, 03:58:05 PM »
That was an interesting read, thanks for posting it. I wonder how many engine machine shops have hot honing abilities? Probably the same number of shops that actually have torque plates.
~Joe
chris401
« Reply #13 on: September 18, 2015, 09:40:03 PM »
A local shop closed its doors after decades of business. Like you said good machinist get old and hard to replace. Crankshaft and Valve was it way back in the day.
« Reply #14 on: September 19, 2015, 06:48:21 AM »
Torque plates are fairly common.  Hot honing remains very rare to see in practice.  Its just based on the amount of work necessary, the percentage of gains found, and the willingness of customers to pay for those gains.
