Author Topic: Kuntz 527 FE 1100 HP?  (Read 13377 times)
PinnaclePeak
« on: September 08, 2015, 11:58:29 AM »
Mornin Gents
Have seen the video of Kuntz 527 FE with special heads making over 1100 HP.
Your Thoughts on reliability and cost?
PinnaclePeak
Re: Kuntz 527 FE 1100 HP?
« Reply #1 on: September 08, 2015, 12:12:17 PM »
He has put together a few 1000hp + Fe's . Personally I think a 1000hp Fe is as reliable as any other 1000hp push rod engine as long as the good stuff is used .. cost $ ? Well yeah, theres the deciding factor. ..  maybe oneday,  in my dreams at least.
« Reply #2 on: September 08, 2015, 12:43:29 PM »
Aren't the heads on that motor $10K+?  Seems like a lot for a wedge motor.  I don't see why it wouldn't be reliable though, as long as you fed it the correct gasoline.  I'm sure that engine is 15:1 or something like that...
whitea62.7t
« Reply #3 on: September 08, 2015, 02:05:32 PM »
Visner Billet heads $6500 EACH  WOW
« Reply #4 on: September 08, 2015, 06:29:56 PM »
He had a video of another 1000+hp with cast heads. Can't tell for sure which they are though.
https://youtu.be/OKfWGll-Umw
« Last Edit: September 11, 2015, 09:38:58 PM by Nightmist66 »
Autoholic
« Reply #5 on: September 08, 2015, 06:38:30 PM »
For that kind of money, I think you would be happier building a SOHC. While you won't produce that much power, Jay can tell you how much power is possible. His last one had like 800+hp and his yet to be released one I'm willing to bet is in the 900 range.
$6500 per head? Damn, you could create a DOHC FE for that kind of money. Once you're building a billet head, there is little difference between a pushrod and a DOHC in terms of cost of the heads. Obviously you'll have to dish out more for cams. Just imagine, a 4V, quad cam FE...
« Last Edit: September 08, 2015, 06:42:33 PM by Autoholic »
~Joe
« Reply #6 on: September 08, 2015, 06:46:50 PM »
Jared,
Thats the video I use to crank through my stereo out in the shop when the neighbors are cranking up there hip hop lol.
« Reply #7 on: September 08, 2015, 07:00:55 PM »
I'm still considering setting the short vid of the 527 1112hp one as my alarm. Would actually make me want to get out of bed. ;D
« Reply #8 on: September 08, 2015, 09:03:19 PM »
No reason you cannot make over a 1000 with a Cammer.
I had one at 527 inches make 870 at 7000 with only 11.5:1 compression, no air pump, and a cast intake.
As far as I know Kuntz has built the only three or four 1000+HP FE wedge motors.  Been kinda hoping to see one of the 1000+HP wedges on the track - anybody know where they've ended up?  I was somewhat involved with a wedge that got over 900HP and the car has gone 8.70s in a fairly heavy car.  If one on those big guns gets into a featherweight car we could see a 7 second FE wedge - how cool would that be?
Qikbbstang
« Reply #9 on: September 08, 2015, 09:23:36 PM »
Can't believe how tame that beast sounds following the pull.
https://www.youtube.com/watch?v=i9g3ruuQLhs
CaptCobrajet
« Reply #10 on: September 08, 2015, 09:27:53 PM »
Jim Kuntz is on my "short list" of really smart engine men.  Reliability of such a beast would largely depend on camshaft.  The valvetrain.....everything above the cam.......will be high maintenence.  As far as cost....you could just call Jim.  Something like that from my camp would be +/- $50K.
Blair Patrick
BH107
« Reply #11 on: September 08, 2015, 11:42:38 PM »
Speaking of max effort FE engines Blair, has work been started on the "fastest FE doorslammer" that was mentioned a few months back?
BTW, I saw Eric's engine in Colorado... Work of art!
« Reply #12 on: September 09, 2015, 07:46:03 AM »
Qikbbstang
« Reply #13 on: September 09, 2015, 09:03:59 PM »
Darn those Visner heads just have that Pro/Stock looking ports. Do they have coolant passages?
« Reply #14 on: September 10, 2015, 05:53:41 AM »
Quote from VED web sight.
 Our Billet Force FE Ford cylinder heads are ideal for any maximum effort FE Ford.  All Billet Force cylinder heads are fully water jacketed and can be customized to fit your exact needs.
quote author=Qikbbstang link=topic=3050.msg30885#msg30885 date=1441850639]
[/quote]
