Author Topic: Lykins Motorsports 511 Tunnel Port, 723 hp, 657 tq  (Read 14881 times)
« on: September 05, 2015, 05:37:17 AM »
Performance Summary:
      Cubic Inches:   511            Dyno brand:  Stuska
      Power Adder:               Where dynoed:   Dale Meers Racing Engines
      Peak Horsepower:  723 @ 7000
      Peak Torque:  657 @ 4500
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond cast iron, 4.375"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat steel, 4.250" stroke, 2.200" rod journal
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Lunati H-beam, 6.800", ARP 2000
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec, 2618, coated, 11.8:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul, Federal Mogul, Durabond HP
   Piston rings brand, size, other notes:  Total Seal, .043/.043/3mm, low tension for vac pump
   Oil Pump, pickup, and drive:  Melling HV, Moroso pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Moroso road race T-sump, no tray, POP billet adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams solid flat tappet, nitrided, 270/280 @ .050", 108 LSA, 108 ICL, .650/.650 gross lift
   Lifters brand, type:  Crower Coolface SBF EDM
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Custom ported Ford Tunnel Port
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Ferrea hollow stem, 2.250"
   Exhaust valve brand, head size, stem size:  Ferrea 1.76
   Valve springs brand, part number, specs:  PAC 1255X, beehive
   Retainers and locks brand, part number, specs:  PAC titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Trend, 5/16" .105" wall
   Valve covers, brand, type:  Holman Moody
   Distributor brand, advance curve information:  MSD, all in by 2500
   Harmonic balancer brand:  Powerbond SS
   Water pump brand, type (mechanical or electric):  CSR
   Intake manifold brand, material, porting information:  Factory Tunnel Port
   Carburetor(s) brand, type:  (2) QFT 725cfm carbs
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tube
« Last Edit: August 16, 2020, 05:54:21 PM by blykins »
Re: 511 Tunnel Port, 723 hp, 657 tq
« Reply #1 on: September 05, 2015, 05:39:40 AM »
« Reply #2 on: September 05, 2015, 06:07:08 AM »
Nice work..
is that a GZ vac pump. ? How about the mounting bracket, is that a custom made piece ? Need to fab up a mount for my setup or modify one to work.
« Reply #3 on: September 05, 2015, 06:09:36 AM »
Everything is GZ.  One of the best setups out there, IMO.  Comes with crank mandrel, mounting brackets, all hardware.  It would have come with the fittings and hoses, but I wanted to make my own hoses to match the engine.  Even comes with a little puke tank.
« Reply #4 on: September 05, 2015, 06:22:38 AM »
Very nice setup. Great build. Thanks for sharing.
« Reply #5 on: September 05, 2015, 02:45:01 PM »
Nice job on that one, Brent, that is outstanding power for a flat tappet cam.  Also +1 on the GZ Motorsports stuff; I have run those pumps on my engines in the past with excellent results.
« Reply #6 on: September 13, 2015, 06:42:36 PM »
I was very pleased with it.
I realize that we were probably down 20-25 hp to a solid roller setup, but I just felt more comfortable going this way.  Used a Comp XTX intake lobe and a High Torque exhaust lobe.  No signs of valve float, even at a little past 7000 rpm.  Everything was very light, from the hollow stem Ferreas, to the PAC titanium beehive retainers that feel like feathers in your hand.
When I do solid rollers for street applications, I'll use the bushed Crowers/Iskys/Morels, and when you're looking at $1000 for just the lifters, the solid flatties seem like a sound alternative.
427HISS
« Reply #7 on: June 05, 2016, 07:33:14 PM »
Nice.
Apx how much would this motor cost ?
« Reply #8 on: June 06, 2016, 09:12:59 AM »
Probably in the $18-20k range, depending on the going rate for Tunnel Port heads, intakes, and how much work they need before they are usable.
