Author Topic: A slight change of plans...  (Read 11671 times)
« on: September 03, 2015, 07:18:02 PM »
I had planned on using Jay's intake adapter and a tunnel ram on my next engine build. That is until I came across this piece. I always like to keep things looking a bit old-school, and since the next build will be going into a late '50s Ford, if I can get this thing to work, it will be going on my dedicated street/strip build.
I guess I'll just have to find something else to use the adapter on. That shouldn't be too difficult ;D
Re: A slight change of plans...
« Reply #1 on: September 03, 2015, 07:35:25 PM »
Nice polishing job.. sweet.
Are both center manifold mounting holes drilled on your PSE or just one on either side like Jays adapter ?
Autoholic
« Reply #2 on: September 03, 2015, 07:40:24 PM »
Some serious porn right there.   :D
~Joe
« Reply #3 on: September 03, 2015, 08:02:10 PM »
Keith, both holes are drilled.
« Reply #4 on: September 03, 2015, 08:45:21 PM »
Thanks. Was just curious.
Mine to.
I had to drill the extra holes in jays only because I rely on them on the drivers side for my linkage.
Impatiently waiting on my block to be done. All aligned bored and decked. Only needing bored but Someone borrowed the torque plate though and wont have it back till Tuesday..  >:( . Maybe ill be sick a half day tomorrow and take the 90 ride and pick it up myself.  :P .
Don't you love how people borrow stuff then conveniently don't bring it back.. uggh.
Did you do the polishing yourself or you acquired it like that ? Looks nice..
« Reply #5 on: September 03, 2015, 08:51:38 PM »
I got it just as pictured. The polish job isn't a 100% show job, but it looks nice. I believe it will need some port work to work with the heads I plan on using, but I'm going to try everything I can to make it work. This was the reason for me asking about port epoxies in an earlier thread.
As a rule, I typically don't loan out stuff, for that very reason. I usually forget who I've loaned it to. I also suffer from terminal disorganization ::)
« Reply #6 on: September 03, 2015, 09:10:26 PM »
I'm sure you will be able to get it to work no prob. I had to fill the floor of my PSE runners quite a bit as well on the intake side to make the Cleveland 2v pro power sheet aluminium manifold work. I used epoxy as well so it would be easy to hog back out to 4v if needed. I have been using some stuff that came from a roundy round guy. He gave me a shoe box with several A and B tubes in it and I ha e used it for several years. There plain white tubes and when he gave it to me he called it Pro-Poxy. He worked at NASA and had gotten it from there. I have never been able to find any info on it because all they are are tubes with an A and a B on it. Unfortunately he passed  :-\ so I can't ask him. I have very little left.. truthfully it kinda looks like JB weld lol but it seems to bond well and I have never had an issue with it coming loose although I still will sometimes use a mig with .035 aluminum wire and just stick a few stakes for it to grip.
« Reply #7 on: September 03, 2015, 10:53:53 PM »
That is a sweet piece.
What car is it going into?
« Reply #8 on: September 03, 2015, 11:00:27 PM »
Sorry, Marc, you'll have to wait on that one ;)
« Reply #9 on: September 03, 2015, 11:09:12 PM »
Bwahh haha
Thought I might catch you in a weak moment. ;)
GJCAT427
« Reply #10 on: September 04, 2015, 05:32:40 AM »
Doug, who made the fuel rail? I`d like to make something similar for my setup.
« Reply #11 on: September 04, 2015, 06:25:26 AM »
I'm not sure. It's a very nice piece though. I'll see if I can find out from the previous owner.
« Reply #12 on: September 04, 2015, 09:22:46 AM »
That is a nice looking setup, alright.  I assume you got a decent deal on it?  One of the reasons I started building my adapters was that the PSE adapters kept going for stupid money on ebay, which made them a really cool part at an unreasonably high price.  Kind of like SOHC stuff ::)
« Reply #13 on: September 04, 2015, 09:57:33 AM »
Jay, you forgot extremely rare too. I'd venture no one know exactly how many PSE made, likely not many. Kudos to your efforts to give the FE a wide range of modern intakes.  ;)
Lenz
« Reply #14 on: September 04, 2015, 10:03:42 AM »
Looks sweet Doug.  I'd add that any late 50's Ford would look pretty good with that setup on display.  It's almost as clean as the undercarriage of your Mach 1 ;D.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
