Author Topic: Failed oil filter pictures....  (Read 17172 times)
« on: August 27, 2015, 08:02:17 PM »
I'm mostly posting these for BB, but others may find it interesting too. This was the filter I mentioned in the "Lost oil pressure" thread.
Quick re-hash of the story. A van lost oil pressure (an E350 with a 5.4). After the 2nd time starting to confirm no oil pressure, it suddenly came back after the 4th start. It was only started for a few seconds each time. I pulled the cheapo Fram filter off and this is what I found....
I could pick pieces of filter media out from the center port, just sitting on top. This is the port that feeds the engine. I knew then that it had sent who knows how much of this garbage into the engine. Well, the engine lasted about another 6 months before it started knocking like hell and was trashed.
Today I finally cut the filter open. I just took a hacksaw and carefully cut around the outside since I wasn't too concerned about getting metal particles in the filter. I already knew what had happened, but wanted to see the insides, and to post this for BB to see. It was obvious that the filter had plugged (I don't know why, the oil and filter only had a few hundred miles on it) and had then built enough pressure to collapse the internals, thereby tearing apart the filter media and sending it down the oil path. This is what it looked like inside....
With the anti-drainback flapper removed, exposing the top of the filter itself....
Bottom line is....don't EVER use a Fram filter. Or any other cheap filter for that matter. The old adage "you get what you pay for" applies in spades here. I never use Fram, Quaker State (they had issues with the same thing some years back) or any cheapo "house brand" filter. If you go to a Quickie Mart oil change type of operation, this is what you're going to get. Buyer beware! As car guys, I'm sure we all know better than to trust those places, but if you think you can save a few bucks, think again.
Re: Failed oil filter pictures....
« Reply #1 on: August 27, 2015, 08:38:47 PM »
How bout the Motorcraft FL-1A?  I've used it for years, and it happens to be cheap (<$5).  Haven't heard anyone mention whether they've had good or bad experiences with it.  For me it has worked fine.
Thanks,
Bruce
« Reply #2 on: August 27, 2015, 08:46:59 PM »
I've never had an issue with the FL-1A. I nearly always use them on my mild street engines. For builds using an HV or HP pump, I usually used the FL-1AHP version. Recently I've switched to the Canton replaceable cartridge on my Mach 1. I like the no bypass feature and easily accessed filter media. I don't think you can go wrong with the FL-1A or Wix on a street car. And BTW, the Napa Gold and Platinum filters are just rebranded Wix.
shady
« Reply #3 on: August 28, 2015, 08:50:23 AM »
ford had a bulletin out on not using aftermarket filters in 5.4's. seems like filter media gets stuck in the small oil passages in the timing chain tensioner circuit causing tapping noise & voiding warranty.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #4 on: August 28, 2015, 08:56:27 AM »
Doug, thanks for those pictures.  Its hard to believe that a filter could collapse in on itself like that.  I think you are correct that it must have been plugged, and the pressure from the pump ended up collapsing it.  But most filters have a bypass that allows oil to go around a plugged filter element (for those folks who don't bother to change their oil and filter very often).  I assume that the Fram PH8A filter has that bypass?  I wonder if it was stuck or something...
By the way, I agree 100% that the Fram PH8A filters are junk, but their HP1 filter isn't that bad.  I've used them in a pinch with no bad results.  I always prefer to use Mobil 1 filters, but keep a couple of the HP1 filters around in case I inadvertently run out of the Mobil 1 units.
427Fastback
« Reply #5 on: August 28, 2015, 01:05:53 PM »
That's pretty disturbing....I am not a Fram filter guy either.I use Motorcraft filters.
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #6 on: August 28, 2015, 02:42:10 PM »
Jay, to be honest, I don't see any type of bypass on it. There is a raised sheetmetal "plug" that fits under the filter media. I don't see any purpose for it other than to keep the media against the top of the housing. The only way I could see it working as a bypass is if it collapsed and pushed down, allowing the oil to pass through the top. But I can't see that actually working that way. I should have shown that part of the filter also.
I can't get any more pictures now because I'm at the NMCA Finals in Norwalk for the weekend. Watching Don Fotti and his '68 CJ car, there aren't many FEs here, sadly. And I agree, their HP1 filter is not a bad filter. I should have been clearer when saying that about Fram's.
Having known what happened to the media, if this had been one of my engines, I would have pulled it and torn it down. But this was a campus owned vehicle and I didn't have that option...nor would I have wanted to if I did :) I use Napa Gold filters at work, but someone took this one to a local garage without my knowledge.
« Reply #7 on: August 28, 2015, 07:09:48 PM »
Hey Doug, that looks like the "Tough Guard" filter, is that correct? I wonder why it has no bypass. ??? Did it use a coil spring and seat or leaf spring style in bottom? What is also surprising to me is that it appears to be one of the more expensive Fram filters, but yet it doesn't have a silicone anti-drainback valve. You couldn't pay me enough to use a Fram filter. JMO
« Reply #8 on: August 28, 2015, 08:39:17 PM »
Jared, honestly I don't know exactly which filter it is. I'm not sure if it says on the filter and I didn't look to see. It does not have a spring in the bottom. You can actually see the bottom piece in a couple of the pictures above. It's just a stamped metal piece that appears it's only function is to hold the filter media against the top of the housing. I don't see any way that it could act as a bypass, but I'll look at it more closely when I get back.
« Reply #9 on: August 28, 2015, 08:52:26 PM »
Looking back at the one pic, I see the leaf spring style end but no bypass in it. It looks like it is just a flat disc in the center of the spring. Unless it looks like this on the bottom side of the spring...
« Last Edit: August 28, 2015, 09:03:43 PM by Nightmist66 »
Lenz
« Reply #10 on: August 29, 2015, 07:30:07 AM »
Wow, this has been an eye opener for me.  Never heard of these Fram problems or the risk of running Fram's PH8A.  I've been driving my Galaxie a ton and the 445's a blast on the street.  Good to know I have a ticking time bomb for a filter.  Thanks for sharing- Len
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
GJCAT427
« Reply #11 on: August 29, 2015, 09:49:42 AM »
Lenz, I have motorcraft FL1-As on both of my 427s, I buy them at wally world for $3-4. I keep a couple around at all times. No ribfest at NE this yr, But the wine fest is a go! Hopefully better parking!
« Reply #12 on: August 29, 2015, 12:18:31 PM »
Jared, no it does NOT have that spring assembly. It is just a stamped metal piece. Interesting. It's hard to believe they don't put one in all their street filters. But even if they had, that means the filter would have gone into bypass and put unfiltered oil through the engine for another 4500 miles before it got changed again! :o  Seems to me that the results could just as well have been the same.
shady
« Reply #13 on: August 29, 2015, 02:34:45 PM »
It's just like everything else these days. hokey manufacturing relying on an old name that had a very good reputation. I can remember 50 years ago (depressing,.... the 50 years, not the fact that I can remember) when fram was king. It was sold & bought a bunch of times getting shittier every time.
amdscooter
« Reply #14 on: August 29, 2015, 05:11:50 PM »
Never fails to amaze me how a $5 item can easily crap out a larger piece of equipment worth many times more. I've been using the K&N oil filters hoping at the very least the extra coin gives some better build quality.
