Author Topic: $$$ crank plugs  (Read 4956 times)
Ranch
$$$ crank plugs
« on: August 26, 2015, 06:54:13 AM »
I was thinking about replacing the screw in steel plugs with aluminum plugs. Getting the crank cleaned up and thinking maybe lightening up a little.
Pro's and con's? Am I messin up?
Re: $$$ crank plugs
« Reply #1 on: August 26, 2015, 10:06:24 AM »
It will change the balance....
Ranch
Re: $$$ crank plugs
« Reply #2 on: August 26, 2015, 10:48:03 AM »
I sorry Brent I didn’t mention it will be a .010 grind with new pistons and rods so a balance is definitely in order, was just wondering about dissimilar metals.  More or less figured since I’m in there, maybe a plug change wouldn’t hurt.   Maybe I’m over thinking this.
Still appreciate the reply.
Re: $$$ crank plugs
« Reply #3 on: August 26, 2015, 11:05:06 AM »
Not sure about that one.  I normally remove the factory plugs and replace them with ones I buy from McMaster Carr.  They have a thread locking compound on them.
Re: $$$ crank plugs
« Reply #4 on: August 26, 2015, 11:56:07 AM »
I once had an 'XE' engine that was factory-born as a "Boss 327" during the later stages of the original SCCA Trans-Am series. The crank was a forging with hollow throws. The plugs were aluminum, sealed with 'O' rings and held in with Spira-Locks. It seemed to me to be a good idea at that time and I've never seen anything that'd change my mind.
