Author Topic: FS: Ford FE 428/427 partial engine packages  (Read 6249 times)
jgkurz
« on: August 25, 2015, 11:18:06 AM »
Posting these for a friend. I AM NOT THE SELLER
Below are two Ford FE partial engine packages with various high performance parts. I am selling each as a package. I will not sell parts separately. NO TRADES, CASH ONLY. Located in Jackson, MI. Local pickup only. Contact me at scaryfast69ATgmailDOTcom if interested.
FORD 428 DRAG RACING ENGINE
A block - C6MF Casting number
Freshly assembled shortblock
WATER JACKETS ARE FILLED WITH EPOXY
CobraJet crank
LeMans Rods
Forged high compression pistons
Milodon 7qt pan and pump
ATI Super Damper
MSD Distributor p/n 8594
Pertronix 7mm spark plug wires p/n 708104
Solid roller camshaft and lifters (Unknown specs)
Dove aluminum intake with 4150 top
CobraJet Heads - C80E-N - Not bolted on engine
Fully assembled heads with 2.08 Intake/1.65 Exhaust
K-Motion triple springs
68cc combustion chambers
Dove Adjustable rockers
Aftermarket pushrods
Dove aluminum waterpump with a welded AN fitting on inlet
Price: $3250.00
Ford 427 CENTER OILER ENGINE
CRANK & RODS ARE NOT INCLUDED
C3AE-AB Casting number
4.280 bore
One sleeve on #6 due to porous cylinder wall
Cylinders have little use
Forged CP high compression pistons with .990 pins
Pistons requires a custom 4.300 stock crank
Dove aluminum cylinder heads
Fully assembled
Fully ported and flowed with records
Ferrea 2.250 Intake/1.750 Exhaust valves with 11/32 stems
K-Motion Springs
Smith Bros Pushrods
Dove Intake port matched to Dove heads
Oil pump
Timing chain and cover
Oil filter adapter
Head and intake bolts
Lunati solid roller camshaft with Crower roller lifters
.730In/.713Ex LS109
No crank or Rods are included
Price: $3500.00
anglia
Re: FS: Ford FE 428/427 partial engine packages
« Reply #1 on: August 25, 2015, 08:44:44 PM »
I am interested in all of the above parts but I can not get that email address to send a message, I am only 45 miles from Jackson. can you PM me a phone # Thanks
jgkurz
« Reply #2 on: August 26, 2015, 09:06:58 AM »
I'll PM you. For DOT use . For AT use @. Just trying fight the SPAM bots.
anglia
« Reply #3 on: August 26, 2015, 09:12:14 PM »
Thanks
jgkurz
« Reply #4 on: August 27, 2015, 07:34:58 PM »
Parts are SOLD
anglia
« Reply #5 on: August 29, 2015, 04:44:57 AM »
Great guy to deal with
