FE Technical Forum
I was wondering if there would be any reason(s) to not run an aluminum spacer
Topic: I was wondering if there would be any reason(s) to not run an aluminum spacer (Read 4857 times)
Qikbbstang
August 21, 2015, 08:57:52 PM »
with the common steel sleeve at the timing cover seal surface instead of the production iron/steel FE crank spacer? .... There's always folks whittling on cranks to reduce weight and even going as far as machining a daisy pattern out of the rear flange to reduce weight.
At 1lb 4.5oz for a production spacer I presume you could shed around a pound by using creative machining and aluminum? ....I believe by the book it would require re-balance on a retrofit or perhaps the aluminum spacer could be counterweighted when machined. You pay big bucks for an aluminum or carbon fiber driveshaft so why not?
Last Edit: August 21, 2015, 09:07:01 PM by Qikbbstang
Truth stands on its own merit.
Re: I was wondering if there would be any reason(s) to not run an aluminum spacer
Reply #1 on:
August 21, 2015, 11:11:36 PM »
Aluminum was available for a while, but it has the tendency to wear where the seal rubs, and leaks. Joe-JDC
427Fastback
Reply #2 on:
August 22, 2015, 12:08:18 AM »
Aluminum weighs 1/3 what steel does...The spacer would have to be hard anodized to tolerate the seal..Very,very few are anodized..
1936 Diamond T 212BD
1990 Grizzly pick-up
Reply #3 on:
August 22, 2015, 07:34:21 AM »
The Blue Thunder ones are hard anodized and seem to work OK.
We have been making aluminum ones that incorporate the "stainless repair sleeve" as a wear surface.
I still prefer steel.
FE Technical Forum
