Author Topic: PSE Base/intake combo. SOLD SOLD  (Read 4468 times)
« on: August 18, 2015, 09:21:55 PM »
SOLD
FOR SALE
PSE Fe intake base/Cleveland 2v-3v sheet metal intake combo. I have had this base for 15 years and it has served me well, right now its port matched to a pro power fabricated intake. I used pro poxy for the ports so it can easy be hogged back out to a 4v if wanted. This base has been massaged a few times but is in great shape with no leaks. Needs a good home and some massaging and is a great candidate for someone. I had planned on keeping the base and using it on the nostalgia blower motor with a Cleveland blower manifold but the guy decided to go small block, Its plumbed for reverse cylinder head cooling but ill furnish caps or you can remove fittings and instal 3/8" npt plugs. Intake runners are also tapped to 1/8" npt and pluged for old style fogger nozzles.  The Cleveland fabricated intake has had the belly cut out so its pretty much only good to be used on a base or could be used on a Cleveland with a modified/fabricated belly pan. Includes neoprene custom intake gaskets, stainless hardware,  brass caps for flair fittings.
Also available is a holley 850 annular boster dbl pumb carb. No choke, duel 50cc pumps , rear jet exstentions, nice old carb ready to run.
Port matched Adapter base  + manifold combo - $900.oo
Add carb - $300.oo
Full or part trades considered,  what ya got ?
« Last Edit: September 27, 2015, 10:46:04 AM by fekbmax »
Re: PSE Base/intake combo
« Reply #1 on: August 18, 2015, 10:57:18 PM »
I can't believe how many times ole Paul had to put his name on his products. He seemed very proud of them. ;D ;D Nice workmanship on the tunnel ram, did you make it yourself?
« Last Edit: August 19, 2015, 06:41:46 AM by Nightmist66 »
