Author Topic: Melling Myths & Fables  (Read 6695 times)
« on: February 09, 2012, 05:37:30 AM »
Re: Melling Myths & Fables
« Reply #1 on: February 11, 2012, 09:31:02 AM »
I saw this post over on the other Forum and now remember seeing it some years ago as well. I agree with their conclusions generally but would add that:
-Some FE oil pans, even with unclogged head/valley drains, can and will pump themselves dry at sustained high rpm levels unless one overfills the pan from factory specs. Yes, lifters are somewhat self-limiting but that's only part of the issue. Keep in mind that passenger car pan design wasn't optimized for high rpm sustained engine operation, especially with high pressure pumps.
-OEM 427 S.O. stuff used cast cams and cast ditzy gears, all good as noted even with high oil pressure. Today, mixing say a steel roller cam with the wrong ditzy gear (like a cast gear) will eat up that gear in a hurry. Likewise, a bronze gear on a steel roller will wear faster than the correct steel cam/steel gear setup or what is advertised as a compatible gear material by the cam maker.  Pays to closely check any brass gear often for excess wear especially on a steel roller.
Interesting too that I do believe many of today's dizty gear failures are often ascribed to excess oil pressure when in fact they could be caused by low ZDDP content in some oils and/or incorrect gear placement (too low or too high on the ditzy shaft) when one replaces a gear without closely checking for the correct measurement. JMO.
« Reply #2 on: February 11, 2012, 12:58:00 PM »
I totally agree on the low zinc levels wiping out the gears ..... two of the cams I replaced were do to distributor to cam wear , I have Schubek lifters with no break in needed but lost 2 cams(gear that drives the dizzy) and dizzy gears to low zinc , the second cam was wiped after the 100 psi pump was replaced with a stock unit .... both cams were wiped with less than 200 street miles
« Reply #3 on: February 11, 2012, 06:54:31 PM »
I think some fast wearing gears can be attributed to misalignment.
If the mesh is not correct just as in any gear mesh you will get excessive wear.
Here's the MSD blurb.
http://www.msdignition.com/instructions/Products/Tech_Info/gear_install_frm28590.pdf?terms=distributor+gear
The mention of the Ford 427 FE "sideoiler" is kinda kool. lol ::)
