Author Topic: 390 Block Question  (Read 6791 times)
ChiefDanGeorge
390 Block Question
« on: July 19, 2015, 06:00:14 PM »
What should I look for when searching for a 390 block to use for my build? The more I read, the less sure I am on what I should be looking for. I'm looking to build a replacement for my '63 Colony Park. My goal is to have something around 350 HP.
Thanks for any advice!
« Last Edit: July 19, 2015, 06:16:19 PM by ChiefDanGeorge »
Re: 390 Block Question
« Reply #1 on: July 19, 2015, 07:44:34 PM »
At that power level you are simply looking for something with standard or no more than a .030 over bore (so you have room to tune it up), and no big damage - a block with cracks, damage, and scored cylinders is not worth purchasing when good ones are under $400.
ChiefDanGeorge
« Reply #2 on: July 19, 2015, 07:48:33 PM »
Thanks for the reply. Are there any particular years to look for or avoid?
« Reply #3 on: July 19, 2015, 07:57:36 PM »
Look for cracks alongside the head bolts, and alongside the freeze plugs.
Make certain you get a post-'64 block with 4 bolt motor mounting holes.
I prefer nice greasy looking ones over those having a fresh coat of Krylon
ChiefDanGeorge
« Reply #4 on: July 19, 2015, 08:04:50 PM »
Will there be any potential issues with a later year block and the Merc 'Omatic transmission mounting smoothly?
I'd like to assume that they kept the transmission bolt holes the same between Merc O'matics, Ford 'OMatics, C4s... but I want to make sure.
427Fastback
« Reply #5 on: July 19, 2015, 08:19:03 PM »
Interesting name Chief....Are you here in BC ??.......Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
ChiefDanGeorge
« Reply #6 on: July 19, 2015, 08:23:18 PM »
Nope, South Carolina.
427Fastback
« Reply #7 on: July 19, 2015, 08:49:43 PM »
Cool....I was born in Chief Dan Georges neighbourhood.....
woodboatwayne
« Reply #8 on: July 19, 2015, 09:45:05 PM »
if you only need a block don't overlook the 360, it is exactly the same
