Author Topic: Replacing intake bolts  (Read 8897 times)
cattleFEeder
« on: July 13, 2015, 09:49:06 PM »
I was going to replace the intake bolts on my 390 with a streetmaster intake, whoever installed them just used regular grade 5 bolts with no washers. I am using an ARP kit for the replacement. Whats the best way to do this so I don't get an intake leak? I was planning on doing 1 at time and retorque them to 25 lbs as I go, will this work?
Remember, RPM is your friend
Re: Replacing intake bolts
« Reply #1 on: July 14, 2015, 12:00:23 AM »
The ARP bolts are nice. I like the Stainless, they don't rust up.
You will have to saw a couple of them to get a good fit.
One at a time is fine, but I like a good snug with a box end and check them every once in a while.
« Reply #2 on: July 14, 2015, 05:57:30 AM »
We've done that many times without a problem.  As mentioned by Scotia, you will need to cut some fasteners since the ARP kit is not going to fit in some positions.  Actually I am not sure what manifold the ARP kit does fit...
« Reply #3 on: July 14, 2015, 07:50:38 AM »
If you're into stainless, I use kits from here:
www.alloyboltz.com
You pay $45-50 and you get an entire engine's worth of stainless fasteners.
shady
« Reply #4 on: July 14, 2015, 09:29:18 AM »
nice^ bookmarked that one.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
cattleFEeder
« Reply #5 on: July 14, 2015, 12:59:33 PM »
Thanks for all the info guys.
« Reply #6 on: July 14, 2015, 01:38:52 PM »
Nice looking '66!  ;)
cattleFEeder
« Reply #7 on: July 14, 2015, 07:17:08 PM »
Thanks, I like the blue on your car. My car is 66 GTA clone with a 390 and a C6 behind it. Just got done doing 4 wheel disc brake and putting on rear springs and caltracs.
« Reply #8 on: July 14, 2015, 07:31:16 PM »
Thanks. Which springs did you put on yours? I'm guessing it was the split-mono. I have the Calvert -1" drop split-monos and double adjustable cal tracs. It looks like you have the "street" single hole cal tracs. Underhood looks good too.
cattleFEeder
« Reply #9 on: July 14, 2015, 08:05:15 PM »
I went with the calvert split-monos but +1, street cal tracs and their rear adjustable shocks.
« Reply #10 on: July 14, 2015, 09:00:51 PM »
Nice Lane!
Love the Lanes. ;)
