Author Topic: BBM CNC heads now available. Ports designed by Kuntz, CNC by Colvert  (Read 12238 times)
BBMTech
We are pleased to announce the availability of our BBM Ford FE heads with CNC porting. Our ports were designed by Jim Kuntz, and the CNC work is done by Jeff Colvert.
Flow numbers are as follows:
Lift Intake Exhaust
.300 219 160
.400 277 200
.500 321 226
.600 346 245
.700 357 255
.800 368 260
.900 375
Valves sizes used in testing above numbers are 2.250" intake and 1.710" exhaust. No pipe on the exhaust. Ports showed no backup in testing to 1.00" lift. Further details in classifieds.
BigBlockFE
Re: BBM CNC heads now available. Ports designed by Kuntz, CNC by Colvert
« Reply #1 on: July 09, 2015, 05:50:08 PM »
Sounds awesome, Kuntz makes some real power.. who is selling the ported heads...
« Last Edit: July 09, 2015, 06:37:33 PM by BigBlockFE »
« Reply #2 on: July 09, 2015, 07:22:16 PM »
I would imagine you could get them through BBM or Kuntz.
I have been a Kuntz fan for many years and couldn't be happier that he is working a set of heads for me now.
I can't wait to see his work and magic,   but I will lol.
BBMTech
« Reply #3 on: July 09, 2015, 07:46:30 PM »
Heads are ordered through BBM, and Jim Kuntz will prepare them to your specs.
« Reply #4 on: July 10, 2015, 07:25:37 AM »
Doug,  if you've test fit these, what do you consider the minimum cylinder bore for these heads?
BBMTech
« Reply #5 on: July 10, 2015, 10:56:51 AM »
Drew, in this configuration with these valve sizes, minimum bore would be 4.230".
Dumpling
« Reply #6 on: July 10, 2015, 09:27:06 PM »
So, if the heads get a CNC job, what difference does it make which underlying set of heads get loaded in the ?-axis mill?  At the end of the program, whatever heads are in there will be Kuntz heads.
« Reply #7 on: July 16, 2015, 12:42:58 PM »
CNC work looks very nice. Late to post the link, but here it is.
http://bearblockmotors.com/bbm-ford-fe-cylinder-heads/
« Reply #8 on: July 16, 2015, 01:11:10 PM »
Well that's not entirely true.
The spark plug is not in the same location when you compare a BBM to an Edelbrock .
At least on my heads.
There are some great heads out there today and if you going for entry level or looking for MAX effort
each head has it's merits.
Of course the price of admittance is a big factor. ;)
« Reply #9 on: July 16, 2015, 07:22:20 PM »
The interior of the heads are totally different between brands, and you will hit water if you try to run a CNC program designed for a Survival, Pond, BBM, on a set of Edelbrocks.  Each head's casting is made from completely different internals.  Joe-JDC
HolmanMoodyStroppeGang
« Reply #10 on: July 23, 2015, 10:51:33 PM »
Hi BBM tech
Are these on the wider 427  valve centerlines or the narrower 390-428 centerline?
A 428 CJ head versus a modern aluminum FE head is about .115 narrower, so I wondered
