Author Topic: 1969 Mustang - tube chassis  (Read 13593 times)
mike7570
« on: June 29, 2015, 12:25:23 PM »
1969 Mustang Super-Gas - 9.90et (throttle stop) 136mph
Turned off controls and foot braked to a 9.59et @ 141mph (probably a tenth or more left in it, was using altitude jets at Pomona and didn't use trans brake)
Alston Chassis, fiberglass front and doors, lexan windows
Original H&M 427 tunnel port purchased from Mickey Thompson.
9.59 configuration - 2,600lb
Side oiler block as delivered from H&M
bored .017 over to 4.250
427 steel crank offset ground to 3.99 stroke (452ci)
Eagle 6.800 rods, 2.20 journal
Arias custom pistons (13.5 -1)
stock tunnel port heads (replace lightweight exhaust valves with Manley's) Titanium retainers.
FPP roller rockers
stock tunnel port 8v single plane intake- two 660 Holley's
Solid flat tappet Comp cam .653/.678  266/276 @ .050
2 1/4" custom headers
Powerglide trans 5K stall Munssinger converter
4.86 gear 14.5Wx32x15 Firestone
« Last Edit: June 29, 2015, 08:28:48 PM by mike7570 »
Re: 1969 Mustang - tube chassis
« Reply #1 on: June 29, 2015, 02:04:14 PM »
Nice....   :)
whitea62.7t
« Reply #2 on: June 29, 2015, 03:28:04 PM »
Nice car
« Reply #3 on: June 29, 2015, 04:57:49 PM »
 8) 8) 8)
« Reply #4 on: June 29, 2015, 07:27:24 PM »
Mike, your car always looks good. How long have you had it now?
I'm also curious how high you spin the engine. Launch? Shift? Traps?
Cam lift isn't out of this world, so it should be fairly easy on the valvetrain.
« Reply #5 on: June 29, 2015, 08:04:50 PM »
Nice car. ;) I am curious on the headers though, does it really need any more than 2 1/8"?
mike7570
« Reply #6 on: June 29, 2015, 08:25:23 PM »
I had the car about 10yrs, sold to spend time with kids. Started father & son stock eliminator build ('67 Shelby)
Son not to interested so it's bogged down to a slow build.
The tunnel port was shifted at 6900 -7000, through the lights about 6900 when throttle stop was on. (7300 on the 141mph run)
Once in a while it saw 8000 by accident on the burn out. Was spinning hard and sounded good. Didn't have the guts to try 8000 on a run.
headers were big 2 1/4" with 4" collectors. (worked fine, I guess, didn't try any others) car left the line on the mat with 5K stall on a trans brake so no need for low end.
I did miss having steel fenders and real glass (that could roll up and down) fiberglass and lexan has it's drawbacks.
I'm hoping the new car will run some good numbers, I've been talking with Blair and putting together the best parts I can. What is hard to come to grips with is I'm spending more money to go slower!
On it's way to a new home.
« Last Edit: February 15, 2018, 04:58:47 PM by mike7570 »
mike7570
« Reply #7 on: May 05, 2020, 03:37:00 PM »
A few more pics of the old car for Turbohunter
« Last Edit: May 05, 2020, 03:43:51 PM by mike7570 »
« Reply #8 on: May 05, 2020, 05:26:18 PM »
Love it Mike.
« Reply #9 on: May 06, 2020, 12:50:10 AM »
That's beautiful, light weight car. Love the TP, too!
gdaddy01
« Reply #10 on: May 18, 2020, 11:25:31 AM »
nice car , the basketball goal reminds me of some of the  pictures I saw of Bob Glidden in the early 70's , in hot rod , I guess . 6x6 cross ties for an engine stand . cool stuff , I thought .
feracer
« Reply #11 on: May 10, 2021, 07:07:07 AM »
Nice....   :)And I thought  I was the only FE in Super Gas car in the country with an FE . And the only one with 2.25 tubes . Guess header companies told you it wouldnt work ,same as me . I piked up 5 mph when changes headers w/o changing anything .Glad to see i,m not the only one doing this . Most people ask me if I have a chevy when I tell them its a 427 , I enjoy telling them Ford made a 427 3 yrs before chev.I use BBMs ported by Jeff Colvert with an old portasonic intake & a 850 QFT .Leave at 5000 & go through at 7200.Have to keep it down as its a stock hydraulic blk . I think it would have died already if the blok wasnt filled to water pump . Brent Lykins helped me when I was pulling insert outa the heads ,told me you need T&D race rockers . That turned out to be good advice . Ran 9.45 at 145 atb 4000 ft corrected 2 sundays ago .2 egt system said 1200 ,so I know theres a little left in it . That was with timing at 30 ,going to my old at 36 next time out .
« Reply #12 on: May 10, 2021, 12:00:40 PM »
sweet car that cranks it out !! Your camshaft specs sound like my Comp cam though I have Schubek lifters
