Author Topic: Valve cover gaskets  (Read 5997 times)
Valve cover gaskets
« on: June 22, 2015, 07:39:07 PM »
Has anyone used these rubber gaskets before?
FEL-PRO Part # VS13049R
Or
VICTOR REINZ Part # VS38308R
Any pros/cons to either?
fastback 427
Re: Valve cover gaskets
« Reply #1 on: June 22, 2015, 08:29:41 PM »
I use the rubber fel pro all the time. I run a small bead of ultra black on both sides to stop leaks. Sick of scraping the cork off all the time!
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #2 on: June 22, 2015, 08:32:01 PM »
I used the Victors on the car during the weekend.
They work for easy off and on.
Not sure I would use them on high mileage non max inspection valve train.
They move around a lot under the covers and are not really well sealed.
But you can get the covers off hot and get right on a rocker check without any hassle.
And get the covers back on and be ready to go pretty quick.
I wanted to do a fast rocker check on a basically untested engine between rounds and they work good for that.
« Reply #3 on: June 22, 2015, 09:34:24 PM »
So, if I understand correctly you siliconed the corks and not the rubber right? I have used the thick Victor corks with steel center with good results. I use clear silicone to hold the gasket to the valve cover and apply a thin smear of oil on the head side to hopefully release easier. The rubber is not meant to have a silicone added by it's purpose. How is the thickness compared to the cork? Is it soft and conformable?
« Reply #4 on: June 22, 2015, 09:36:25 PM »
Thanks for sharing Howie. I think I will probably stay away from those.
fastback 427
« Reply #5 on: June 23, 2015, 12:01:07 AM »
The thickness is about the same as the cork, very pliable. I do use ultra black on the rubber on my cast valve covers, they seem to move around a bit. Some don't use it but works for me, no leaks.
Jaime
top end toploader
« Reply #6 on: June 23, 2015, 12:31:32 AM »
Ok, thanks.
