Author Topic: Ford Experimental Engines  (Read 14749 times)
« on: June 19, 2015, 12:24:21 AM »
Re: Ford Experimental Engines
« Reply #1 on: June 19, 2015, 01:58:02 AM »
Kooool...
« Reply #2 on: June 19, 2015, 09:10:35 AM »
These engines did appear in a Hot Rod magazine long ago. I think the innovative Calliope had the best potential for actual use, in racing as opposed to a true production line engine. At the time Ford was eyeing its use in the Can-Am series where the all-conquering McClaren's used a all-aluminum Chevy rat motor. That and a replacement for the FE in distance FIA racing (read: LeMans) in the GT-40 program, ending with the all-conquering Mark IV in 1967. Too bad as once the FIA severely reduced engine size to limit Ford's GT dominance, Ford pulled out and cancelled this engine. I guess that the Can-AM series did not interest Ford enough to keep even a limited program going. I still think with more development this engine could have been a rat motor killer in Can-Am.
« Last Edit: June 19, 2015, 09:36:33 AM by machoneman »
« Reply #3 on: June 19, 2015, 09:24:49 AM »
That SOHC flathead is cool, would love to hear that one run!
« Reply #4 on: June 19, 2015, 10:15:33 AM »
The "Direct Injection 302" is actually the famous PROCO engine from the late 70's.  PROCO stands for PROgrammed COmbustion, and it was going to be Ford's future.
The description has a few things wrong, in that it did have a distributor (BIG with 16 pins for the twin spark plugs!!)  They ran well,  but then Ford realized that they could get all of the same benefits by adding an overdrive gear to their automatic transmissions, so the multi-billion dollar project was scrapped.  The engines were pretty much tooled for production at that point.  A few examples survive though.
An example of the Calliope 427 was sitting in the lobby of the Dyno building when I worked there, complete with a brace of original 58mm Webers on top!  Somebody finally must have realized how valuable that engine was, because it's been freshened up and only appears at shows from time to time.
« Reply #5 on: June 19, 2015, 12:33:08 PM »
I'll second that!! I have never seen that before and it looks VERY cool. I'd love to have heard what it sounded like. It almost looks like it could have been destined for an airplane application.
« Reply #6 on: June 19, 2015, 01:09:38 PM »
Just my thoughts looks like an early aero engine
fastback 427
« Reply #7 on: June 19, 2015, 06:01:46 PM »
Looks very cool, Ford's advanced technology. They should put that in the starship enterprize, then rev it to warp 9 and dump the clutch ;D  New way to measure 0 to light speed!
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
shady
« Reply #8 on: June 19, 2015, 06:29:33 PM »
Scotty says the dilithium crystals can't take warp 9. Rev limiter is set to warp 7.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #9 on: June 19, 2015, 10:41:27 PM »
"Captain, she can't take any more" ....LOL!
babybolt
« Reply #10 on: June 27, 2015, 06:23:55 PM »
I had a chance to buy a couple of the Proco engines back in the day for $200 each.
One of my friends briefly had a 289 SOHC engine.
The June 1968 issue of Hot Rod has the article you guys are talking about, "Ford's Exotic New V8's".  There are 5 Ford prototype engines on the cover, DOHC 302 3-Valve, SOHC 289 2-Valve, 3-Valve Pushrod 427 Calliope, Turbocharged Indy DOHC, and 'Twisted Chamber' 429 for Stocks.  The last engine listed is first article on the Boss 429.
