Author Topic: 1966 GTA Fairlane  (Read 7177 times)
fallguy72
1966 GTA Fairlane
« on: June 14, 2015, 11:53:54 PM »
Performance Summary:
      1/4 mile ET:    12.872           1/4 mile MPH:102.17
      1/8 mile ET:    8.151           1/8 mile MPH:83.90
      60 foot time:1.786
      Track: Ashcroft B.C. Canada
      Weather Conditions: 29c
Vehicle Use:street car with one trip to the track per year
Vehicle Specifications: stock gta "S" code
Model Year:1966
Model:Fairlane GTA
Style:2dht
Engine Details (link to post in Dyno Results board if available: 445 cid, stock 66gt heads c6ae u, comp cams 280h 230/230@.050 530 lift, 9.8 cr, performer rpm manifold, fpa headers, holley 750 dp
Transmission: c6 with transgo shift kit
Torque converter details (if automatic):3000 stall tcs converter
Clutch details (if manual):
Driveshaft stock weak link broken in half with damage to floor pan
U-joints:regular stock
Rear end type:stock
Differential type:mini spool
Gear Ratio: 3.89
Axles: moser 28 spline
Front tires:225/60 15
Front wheels:centerline
Rear tires: m/t et street 255/60 15
Rear wheels:centerline
Front suspension information: stock
Rear suspension information: stock
Ready-to-race vehicle weight, including driver:3596 lbs
carbidemike
Re: 1966 GTA Fairlane
« Reply #1 on: June 15, 2015, 10:42:37 AM »
sounds like a cool cruiser,those stock shafts can be dangerous w/sticky tires!
fallguy72
« Last Edit: June 16, 2015, 05:22:19 PM by fallguy72 »
« Reply #3 on: June 15, 2015, 06:35:28 PM »
Kool Vid!
Thought you had him with the hole shot, but he nipped you on the big end.
Your gonna need a bigger cam. ;)
