Author Topic: Fe Frustration  (Read 17749 times)
Ean R
Fe Frustration
« on: June 06, 2015, 02:57:02 AM »
I have my 427 side oiler block at an engine rebuilders in Perth Australia.
If you live in Perth you will already be cringing.
All I wanted was the block sonic tested and line honed bored out etc.
They are telling me the bore is at 4.232.
That it hasn't been sleeved but they can't bore it out anymore as the cylinder walls are only  80 thou?
Then they are trying to say it may be something else bored out to 427ci.
3 engine builders, ford gurus apparently, I've been to in Perth. One tried to sell me a small block?
One told me 390's were the same block as the 427 and this one is trying to say it may be a 360 turned into a 427.
Apart from the glaringly obvious fact I have to pick up my block from these people and the equally glaringly obvious fact that the side oiler is unique to the 427 only (410?) is it possible to have an under stock bore that is too thin to bore out to 4.25?
Or should I just take it to another shop? This shop has torque plates for honing etc, only one in Perth apparently.
Any Aussies out there? Willing to send this interstate if I have too. Surely you can get a 427 fe machined properly in Australia somewhere?
Ean Rinaldi
66 Fairlane 500
427 side oiler
Re: Fe Frustration
« Reply #1 on: June 06, 2015, 05:36:42 AM »
Possibly an irrigation block maybe. ? A block deemed not suitable for automotive use because of thin cylinder bores or core shif or some other problems with the casting. Many Fe/Ft blocks that would not pass inspection for automotive use where used for earagation/industrial/farm use because they were deemed to be acceptable for continuous low RPM use.. just a thought, I could be wrong for sure. I found a block just a year ago that was a standard 390 bore but was cast with the cross bolt bosses and appeared to be one of the blocks with the high manganese silicon content,  thought I had a gem. The cylinders were to thin to even do a .030 over bore.  Was a heart breaker.
Re: Fe Frustration
« Reply #2 on: June 06, 2015, 05:49:48 AM »
Where are they measuring.  A 427 with cloverleaf shaped cylinder cores may be pretty thin in some spots, yet still be OK.  The thicker corners in the core will supply some support.  Also possible to add a short layer of block filler if the thin spot is near the bottom as is common - reduces the span top to bottom.
A hone to 4.250 may not be required, pistons can be made to any increment and we have many running at 4.240.  At that point we are only talking about a .0035 reduction in wall thickness.
ToddK
Re: Fe Frustration
« Reply #3 on: June 06, 2015, 05:59:09 AM »
Ean, I saw your block at one machine shop in Osborne Park, not sure if these were the guys who did the sonic check. It would have to have some serious core shift to only have 0.080" wall thickness at standard bore. And like I said to you before, there are not too many engine builders in Perth that really know FE's. I'd be taking it to a different machine shop to get a second opinion on the sonic check. Make sure you get a hard copy of the results and post them up here for the brains trust to assess.
And don't worry too much about the shop having the only torque plate in Perth. The shop where I saw you block, I asked the shop owner if he had a FE torque plate. He didn't, but said there was one available that all the machine shops share.
Re: Fe Frustration
« Reply #4 on: June 06, 2015, 05:59:46 AM »
I wonder too just how accurate their sonic test measurements really are? Did they give you a sonic map of each cylinder and if so, can you post it?
Re: Fe Frustration
« Reply #5 on: June 06, 2015, 06:09:03 AM »
This sounds like you need to tool up and do some of the work yourself.
I'd get your block back and measure it yourself.
There is nothing on the block that you can't measure in your shed with some basic tools.
Hell, you can get the block ready for service in your shed if you want to. jmho
Ean R
Re: Fe Frustration
« Reply #6 on: June 06, 2015, 07:09:16 AM »
Thanks for the quick response fellas.
I've measured it roughly when I stripped it down and it went 4.233 so I thought I'd won the lotto as in it still was original bore size.
The blocks getting sonic checked somewhere else as these guys haven't given me a print out and I doubt they've even checked it.
As to it being an irrigation block, I don't know, it has the steel crank $ stamped, the factory machined chambered heads and fomoco forged pistons, lemans rods with cap screws and ford sidewinder intake.
So from my understanding all the gear that points towards a normal 427. Does have the ribs cast in the block though.
The shop also told me the pistons were very undersized.
The only other experience I've had with big blocks is in a couple of 428 mustangs (weird when you think about it as fe's are rare here)
My Fairlane was a completely different animal to these stangs and the engine was much meaner quicker and louder than either of the 428's.
So surely I haven't got the only 427 block ever poured that's too thin to rebuild?
I'll get proper results and post so the experts can help.
Barry I'm guessing you can supply pistons any size?  I should've known I do have yours and jays books.
Todd I'll pm my number to you again.
Thanks guys and I'll be back with some figures soon.
Ean Rinaldi
66 Fairlane 500
427 side oiler
Re: Fe Frustration
« Reply #7 on: June 06, 2015, 10:24:46 AM »
A sonic check on this block means absolutely nothing.
It is a waste of time and money.
You have a stock bore 427, right?
You're only going to hone the bores to a clean state.
And get pistons to fit, right?
You need to focus on the block.
Does it hold water?
Is it all rusty and need complete machining or is it close to useable?
Is it cracked?
Who cares how thick the bores are? Is it going to change you're plans?
Unless you're going to step up to an after market block or have another 427 stock bore block
sitting beside it. You're going to run what you have? jmo
Re: Fe Frustration
« Reply #8 on: June 06, 2015, 10:39:41 AM »
It is really unfortunate that your local machine shops are this clueless about the FE.  Also FYI on my .060" over 427 factory block I have a couple cylinder walls that sonic check between 0.075" and 0.080" in some spots, but that engine made 650 HP as one of my dyno mules for my book, and I beat it mercilessly in the process  ;D.  Barry is correct, the cloverleaf shape of the bore spacings really helps with the bore strength on the 427 blocks.  Get one of those local shops to power hone that block to the smallest possible finished dimension, and then get a set of custom pistons to match.  I think you'll be just fine with that approach.
BH107
Re: Fe Frustration
« Reply #9 on: June 06, 2015, 03:34:01 PM »
I have a 64 center oiler that is the same. Standard bore with minimal wear, and I took out the original stock pistons. There are several cylinders that were right about 0.080" thick on the sides, showing a good amount of core shift as the other side was nice and thick.
Re: Fe Frustration
« Reply #10 on: June 07, 2015, 07:54:48 PM »
Best advice right there.
If it's really at standard bore, I wouldn't care what any sonic check said, I'd hone it the smallest amount possible and get custom pistons for it. SOME blocks can't handle much of an overbore, some can, but I've never seen a stock bore block be too thin to not use.
And what on earth do they mean "very undersized" pistons? How can they be undersized? Ford had different sized pistons that were available for the stock 427 back in the day, so that cylinder/piston clearance could be achieved WITHOUT overboring or honing. Maybe they're confusing a slightly smaller piston that was used to gain more clearance. It wasn't that uncommon to build an engine "looser" back then so it would wind quick and easy.
Never ever bore a stock sized 427 block just to save money on a "standard" or older set of .010, .020 or .030 oversized pistons. All it does is shorten the life of the block.
Ean R
Re: Fe Frustration
« Reply #11 on: June 09, 2015, 09:30:20 PM »
All I wanted was the block honed, machined or whatever it needed so I could bolt it back together. Not trying to turn it into a 500 cube drag motor.
I'm a complete novice at this and couldn't find a set of stock bore pistons anywhere on the internet?
Hence my thinking it needed to go out to 4.250.
 40 odd year old block and it went just fine before the head gasket blew so this motor can stay at 427 or close enough. I'm using the original crank so big cubes wasn't the goal.
The fact I know more about an engine than the 60 yr old bloke at the machine shop who probably has dealt with 10000 v8's is frustrating to say the least.
These people have never heard the term FE or side oiler!, you try explaining the blocks were poured thin from factory and they look at you like you just slapped them.
Mention clover leaf bores and you may as well  be talking Swahili
Stay tuned I could be the first person to stick an engine block up someone's arse, followed by a set of "very undersized pistons"
Ean Rinaldi
66 Fairlane 500
427 side oiler
Re: Fe Frustration
« Reply #12 on: June 09, 2015, 09:52:32 PM »
A possible reason they are saying the piston is under size is
you have an old set of TRW's and they had a spec of something like .007" clearance.
A tad rattlely when cold.
What's wrong with the pistons?
Ean R
Re: Fe Frustration
« Reply #13 on: June 10, 2015, 06:21:20 AM »
How loose? I've got a feeling 7 sounds right.
It never blew smoke but it did ping (rattle) a bit when pushed hard. I thought it was a loose exhaust bolt or timing?
The bloke says they're forged pistons and they've got fomoco stamped underneath. Valves have hit and scored 2 pistons slightly but I wouldn't know what I'm looking at.
They're all the same shape and not burnt or melted in any way? Rings all look the sme and the bores look brand new. When I first went there he said the pistons were ok, the next they're shot?
Ean Rinaldi
66 Fairlane 500
427 side oiler
Re: Fe Frustration
« Reply #14 on: June 10, 2015, 06:27:04 AM »
Take a bunch of pictures of your gear and if you want I will post them here
for the brain trust to comment on.
my addy 390fairlane@gmail.com
