Author Topic: 1975 Ford FE Powered Sled Puller  (Read 38208 times)
NIsaacs
« on: June 05, 2015, 06:23:09 PM »
Here is a video of my Stock Gas Puller with a 440/428. First pull of the new season. The track was too hard and dry for my tires to hook, note the slow ground speed. I have a set of 35" BFG/AT's that I took off before I added some power because I couldn't pull them, I think I need to put them back on now.
All the guys that I beat last year on the last pull of the season beat me this time, same tires different track. The engine is running good so I think it can handle the bigger tires now. Note the front fenderwell gap at the very beginning before I launch and after, the weight transferred good (1200 lbs) still spinning bad tho.
https://www.youtube.com/watch?v=NHabtNFaz1k
Nick
Re: 1975 Ford FE Powered Sled Puller
« Reply #1 on: June 06, 2015, 07:06:08 AM »
Cool! What rpm's are you hitting?
NIsaacs
« Reply #2 on: June 07, 2015, 05:09:18 AM »
I set the shift light for 6k and about the 75 ft. mark it lit and stayed lit to the end :)
Nick
« Reply #3 on: June 07, 2015, 08:42:41 PM »
Pretty cool!!
That track is definitely dry! There shouldn't be dust flying in the air ???
Sounds like it could really use those bigger tires now! It didn't even begin to bog that engine down :D
NIsaacs
« Reply #4 on: June 08, 2015, 05:38:27 AM »
Thanks, it is running good, thanks to the little tips shared by you guys. My class is heavy (6500 lbs) so no weak sisters allowed ;D Logan, Utah is 4500' in elevation too.
Nick
NIsaacs
« Reply #5 on: June 08, 2015, 09:06:49 PM »
I was in 2nd gear (c6) on this pull, light sled, muddy track and lighter class (5500lbs) still hit some serious rpm tho :)
https://youtu.be/qy9c6kUK24w
Nick
« Last Edit: June 08, 2015, 09:11:35 PM by NIsaacs »
mlcraven
« Reply #6 on: June 08, 2015, 09:31:05 PM »
That has to be a serious test of engine and drivetrain durability!
Michael
« Reply #7 on: June 08, 2015, 10:30:35 PM »
You ain't a kiddin it is!! Driveshafts, yokes, axles, they all take a beating! If it starts to hop, it's gonna break something in a matter of seconds. You better not be afraid of busting something or else you better stay home ;D
People always think drag racing is really hard on stuff, but truck pulling will find weak spots REAL quick.
NIsaacs
« Reply #8 on: June 09, 2015, 05:58:03 AM »
This happens to be a Dodge Diesel, but you get the idea....
https://www.youtube.com/watch?v=jhXlZc7I3fw
Nick
NIsaacs
« Reply #9 on: June 24, 2015, 05:49:01 PM »
My Vernal Utah 2015 pull. I swear, when the weight box hit the top and the shanks deployed I thought my motor was gonna run backwards! Lol
The bigger tires really seemed to help my traction but dropped my rpm down a bunch, the ground speed is there tho.
https://www.youtube.com/watch?v=5Nne33lTMx0
NIsaacs
« Reply #10 on: June 24, 2015, 05:51:30 PM »
My Burley Idaho 2015 pull. Not sure why I am getting some static in the audio.....
Nick
https://www.youtube.com/watch?v=X9wU-U5SCGY
« Last Edit: June 24, 2015, 05:53:27 PM by NIsaacs »
« Reply #11 on: June 25, 2015, 10:07:06 PM »
Boy you were really cookin on that Vernal video! Ground speed is definitely good. That thing looks like it's pulling nice and the engine sounds real good and smooth. Nice job.
NIsaacs
« Reply #12 on: June 26, 2015, 06:10:34 AM »
Thanks Doug, my brother and I both finished 1st in our class. He pulls in the Super Stock class (6200 lbs) with a '78 Ford w/400m of all things lol....The dang boat anchor gets it thou, Vernal is 5300' in elevation. He has been pulling the same truck for 35 years so he knows what works.
Nick
https://www.youtube.com/watch?v=9bRt2bzXj1s
R-WEST
« Reply #13 on: July 27, 2015, 02:18:10 PM »
Quote
The guy who does my engines tells me the only thing harder on an engine than pulling is offshore powerboat racing.
BTW - that is a seriously good sounding FE!!  8)
NIsaacs
« Reply #14 on: August 04, 2015, 06:36:07 PM »
Thanks R-WEST, It is running good this year, 11 pulls so far this season. Going to Colorado Springs next week 6,000' elevation so I am going back to my 31" tires, I think I will need the power. I made some changes to my rear suspension and hitch that seem to work really well with the 35's so I am going to try them again.
Nick
http://https://www.youtube.com/watch?v=uQzvGLv2UDM
« Last Edit: August 05, 2015, 06:15:10 AM by NIsaacs »
