Author Topic: Fairly mild solid flat tappet 428  (Read 8226 times)
« on: May 23, 2015, 06:43:45 AM »
Here's a fairly mild 428 from many years ago.  Ran fine on 91 octane pump gas.   Valve train was little finicky with the aggressive camshaft.
Performance Summary:
      Cubic Inches:  432          Dyno brand:  DTS
      Power Adder:  none         Where dynoed:  K&M Machine, Raytown, MO (defunct.)
      Peak Horsepower:  517
      Peak Torque: 521
Horsepower and Torque Curves:
RPM---HP---Torque
3000--261----456
3100--274----464
3200--288----473
3300--303----482
3400--317----489
3500--330----496
3600--344----502
3700--358----508
3800--371----513
3900--384----517
4000--395----519
4200--417----521
4300--426----520
4400--435----519
4500--443----517
4600--451----515
4700--457----511
4800--464----508
4900--471----505
5000--477----501
5100--483----498
5200--489----494
5300--495----490
5400--500----486
5500--506----483
5600--510----478
5700--512----472
5800--513----464
5900--514----457
6000--515----451
6100--516----445
6200--517----438
6300--514----428
6400--502----412
Engine Specifications:
   Block brand, material, finished bore size, other notes:
Factory Ford 428 "C" block.  4.155" bore.
   Crankshaft brand, cast or forged, stroke, journal size:
Factory 428 crankshaft. 3.985" stroke.
   Connecting Rods brand, material, center to center distance, end sizes, bolts:
Factory CJ rods.  ARP 11/32" bolts. 6.483"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:
JE pistons.  Forged.  Flat tops with approx. 5 cc valve reliefs.  Static compression 10.5:1.  551.5g.  .975" pin.  1.68" height.
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
Don't know
   Piston rings brand, size, other notes:
 1.63mm/1.63mm/4.78mm.  spiro locks.
   Oil Pump, pickup, and drive:
Melling HV with matching pickup.  Heavy duty drive.
   Oil pan, windage tray, oil filter adapter:
Milodon deep sump. 8 quarts.
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050")
Comp Cams solid flat tappet.  270/276 @0.020". 240/246 @0.050".  .598/.608" gross lift.  108 LSA.  107 ICL.  Intake lobe is an XTQ.  Exhaust lobe is a TL.
   Lifters brand, type:
Crower Dumbbells with EDM hole
   Timing chain and timing cover:
Ford Motorsport 9 position chain with factory cover
   Cylinder heads brand, material, port and chamber information:
Edelbrock aluminum. Ported. Intake fully ported.  Exhaust just cleaned up.  CJ exhaust flange.  "72cc cast chambers"  Actual chamber size 79 cc.  45 degree seats.
      Intake               Exhaust
       .050    26.9        .050     25.6
      .100     61.7        .100     53.6
      .200    129.3       .200     97.0
      .300    190.4       .300   131.5
      .400    236.1       .400   162.7
      .500    267.3       .500   191.4
      .550    281.3       .550   -----
      .600    293.4       .600   205.8
      .650    302.8       .650   -----
      .700    -----         .700   213.1
      .800    -----         .800   217.6
   Flow bench used, location:
SF600.  28".   Raytown, Mo.  Approx. 1200 feet altitude.  4.18" bore tube.  Clay radius on ports.  No pipe on exhaust.
   Intake valve brand, head size, stem size:
Ferrea.  2.09".  3/8" stem
Exhaust valve brand, head size, stem size:
Ferrea.  1.655".  3/8" stem.
   Valve springs brand, part number, specs:
Crane 99895
   Retainers and locks brand, part number, specs:
Crane titanium retainer.  Don't remember part number.  Don't remember the locks.
   Rocker arm brand, type (adjustable or non-adj), material, ratio
Harland Sharp.  adjustable.  aluminum.  1.76 ratio.
   Rocker shafts and stands, brand, material:
Harland Sharp shafts. Dove aluminum stands with end stands.
   Pushrods brand, type, length:
Crane.  Stock replacement
   Valve covers, brand, type:
Factory "Mercury Pentroofs"
   Distributor brand, advance curve information:
MSD 8594.  16 degrees initial.  37 degrees total.  Total in around 2800 rpm
   Harmonic balancer brand:
Factory Ford
   Water pump brand, type (mechanical or electric):
Edelbrock mechanical
   Intake manifold brand, material, porting information:
Blue Thunder 1x4.  Port matched to heads.
   Carburetor(s) brand, type
Holley 4781 850 double pumper.  76 jets all around.  Choke horn milled off.
   Exhaust manifolds or headers brand, type:
Crites 2" primary.  3.5" collectors.
edit:  water temp was kept around 160-165 degrees F while on dyno.
« Last Edit: May 23, 2015, 09:51:47 AM by plovett »
Re: Fairly mild solid flat tappet 428
« Reply #1 on: May 28, 2015, 07:13:52 PM »
Just FYI, I took the stroke length (3.985") and the rod length (6.483") off of my old piston order form from 2005.
I was PM'd by a member inquiring about those numbers, as they're not the standard numbers.   It got me to thinking (insert joke here  :o ).
Are those the actual true measurements?  Did my machinist add or subtract a few thousandths on the form he sent to JE for safety's sake?  Did he "move things around a bit" in the machining process and consequently those are correct numbers?  How much variation is there in factory spec's?
I just thought I'd bring that up for the sake of conversation.  Any piston guys or engine builders have some input?
thanks,
paulie
