Author Topic: Lykins Motorsports 427FE, with Eddy's...  (Read 7892 times)
« on: May 15, 2015, 07:14:18 AM »
Performance Summary:
      Cubic Inches:     427          Dyno brand:  Stuska
      Power Adder:     Nope          Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  476
      Peak Torque:  489
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 S/O block, 4.236" finished bore size.
   Crankshaft brand, cast or forged, stroke, journal size:  Factory $ crank, .020/.020
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat 6.490" H-beam
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond forged pistons, 10.7:1, 1/16, 1/16, 3/16
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  King main/rod, FM cam bearings
   Piston rings brand, size, other notes:  Total Seal, standard tension, 1/16, 1/16, 3/16
   Oil Pump, pickup, and drive:  Precision Oil Pumps Melling HV
   Oil pan, windage tray, oil filter adapter:  Canton T-Sump, factory filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Bullet solid flat tappet, 240/246 @ .050", 108/103.5, .620"/.614"
   Lifters brand, type:  Crower SBF EDM
   Timing chain and timing cover:  Rollmaster, factory
   Cylinder heads brand, material, port and chamber information:  OLD Edelbrocks, out of the box with a good valve job.
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Ferrea 2.09, 3/8"
   Exhaust valve brand, head size, stem size:  Ferrea 1.76, 3/8"
   Valve springs brand, part number, specs:  Comp 930
   Retainers and locks brand, part number, specs:  Comp 741
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Precision Oil Pumps
   Rocker shafts and stands, brand, material:  Precision Oil Pumps
   Pushrods brand, type, length:  Trend, 5/16" .105"
   Valve covers, brand, type:  Ford Racing
   Distributor brand, advance curve information:  MSD
   Harmonic balancer brand:  Rebuilt factory
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Blue Thunder 1x4
   Carburetor(s) brand, type:  Holley 750 DP
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:56:06 PM by blykins »
Qikbbstang
Re: 427FE, with Eddy's...
« Reply #1 on: September 20, 2015, 08:38:38 PM »
 Peak Horsepower:  476 @ ? rpm
      Peak Torque:  489 @ ? rpm
  Just be interesting to know I presume they are fairly high RPM
« Reply #2 on: September 21, 2015, 06:11:05 AM »
HP @ 5700.  Torque at 4400.
