Author Topic: Opinions on flywheels  (Read 8165 times)
CDXXVII
« on: January 12, 2012, 10:12:18 PM »
I saw some of Dave's comments about flywheels on the old Forum and thought about retiring my 47 year old factory unit. My car is only street driven so I probably don't need the top Centerforce or Hays unit. I'm not likely to see 7000 rpm on the street but I have no idea on the history of previous abuse on my existing flywheel...
Any suggestions for a zero balance flywheel that will work well and fit to my factory 11.5" clutch. Engine is a C/O 427 from 1965 hooked to a top loader 4 speed?
Re: Opinions on flywheels
« Reply #1 on: January 12, 2012, 10:52:49 PM »
We've been using a Ford Racing part that's made in USA -  seems pretty nice for under 300 bucks.  You can get a Chinese import piece for just over 200.  I have run them on the dyno and they fit OK, but I don't have much experience with them in a car.
rockhouse66
« Reply #2 on: January 13, 2012, 08:51:47 AM »
Barry - I don't see anything that appears correct for FE in the Ford Racing catalog.  Do you have a p/n for this please?
Never mind - I found it on a search of CJ Pony Parts website.  The zero balance version is M6375N427, $288.35.  Thanks for the tip!
« Last Edit: January 13, 2012, 09:12:20 AM by rockhouse66 »
Jim
DEANs427
« Reply #3 on: January 13, 2012, 11:42:34 AM »
Is the "Ford Racing" flywheel SFI certified?
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
CDXXVII
« Reply #4 on: January 13, 2012, 12:20:07 PM »
Thanks for the info. You didn't mention if my factory clutch bolt pattern was standard across the aftermarket.
Summit Racing shows the Ford Racing flywheel for $280. I didn't see anything on Summit priced below that.
Ever have a problem with balance of a new flywheel (whether China or USA)?
drdano
« Reply #5 on: January 13, 2012, 03:21:03 PM »
It says it is for 1.1.
CDXXVII
« Reply #6 on: February 13, 2012, 11:20:39 PM »
The Summit site says the Ford Racing M-6375-N427 flywheel creates interference between the heads of the crank flange bolts and the clutch when using the factory disc.
Anybody seen this problem? I am thinking the thickness of the M-6375-N427 flywheel is greater than the stock flywheel?
