Author Topic: FE Engine Weight Comparo  (Read 19803 times)
TimeWarpF100
« on: May 12, 2015, 11:20:20 AM »
I have seen FE weights numerous times on the net but it seem like half those were guesses.
Out of curiosity I decided to weigh a bunch of FE parts on a newly calibrated scale.
Often one asks how much they will save using aluminum heads, intake etc
I know others have most likely done this but its hard to find info online.
1st up was the total weight of the 1966 352 I had just removed from my F100
1966 352
708 lbs     Complete carb to pan including flywheel, clutch, bellhousing, water pump, fuel pump, distributor, balancer
Pretty much as pulled out of truck.
TimeWarpF100
Re: FE Engine Weight Comparo
« Reply #1 on: May 12, 2015, 11:26:06 AM »
Also curious what a typical FE would be with added aluminum heads and intake.
I built a engine cradle to make weighing much easier and also for storing engine's as needed.
I have a large furniture style dolly to move it around on.
Of course zero out the scale first with the cradle
TimeWarpF100
« Reply #2 on: May 12, 2015, 11:31:09 AM »
As pictured of a 418 complete pan to carb, distributor, water pump, fuel pump, oil and filter, cj valve covers, balancer
468 lbs
TimeWarpF100
« Reply #3 on: May 12, 2015, 11:36:31 AM »
475 lbs same as above but adding a Automatic flex plate
497 lbs same but with Standard counter weighted Flywheel
553 lbs same but adding the bellhousing and clutch/pressure plate & mounting hardware
I will be adding a bunch more soon
« Reply #4 on: May 12, 2015, 11:58:42 AM »
Here's one.  You can't read the scales really easily, but the say 263 and 277 pounds, for a total of 540 pounds.  No flywheel, no starter, no headers.  This is an all aluminum motor.
« Reply #5 on: May 12, 2015, 12:23:34 PM »
I want my garage to have all ^^^^that^^^^ weight in it one day. ;D
TimeWarpF100
« Reply #6 on: May 12, 2015, 12:49:33 PM »
I am surprised how close in weight that is to mine . .
« Reply #7 on: May 12, 2015, 03:31:51 PM »
Here's another one.  This is the low buck 390 build I did for Car Craft several years ago.  Aluminum heads and intake, and everything else factory (including the water pump).  This engine also has headers attached, and a flexplate, although you can't see it in the photo.  509 pounds complete:
« Reply #8 on: May 12, 2015, 07:00:27 PM »
Very interesting thread! 155 pounds is a lot of weight to shed, although the iron manifolds on the 352 would add about 20 pounds over the manifold-less 418, approximately. I'd assume the crank should be lighter in the 352 with a shorter stroke, but maybe equaling out with better/heavier rods in the 418. A steel bellhousing would certainly be much lighter than the iron unit also.
Nice to see that aluminum heads would pretty much counter the extra 50 pounds in my Sideoiler Garage block over a factory iron 427.
Good stuff. Thanks for the post.
TimeWarpF100
« Reply #9 on: May 13, 2015, 12:57:54 AM »
22 lbs diaphragm style clutch setup
23 lbs  Long Style
TimeWarpF100
« Reply #10 on: May 13, 2015, 01:00:38 AM »
64 lbs 352 std std crank
65 lbs 390 .020 .020 crank
I was surprised at this one as always had 70lbs in mind on the cranks . .
« Last Edit: May 13, 2015, 01:03:13 AM by TimeWarpF100 »
TimeWarpF100
« Reply #11 on: May 13, 2015, 01:01:18 AM »
What kind of hp/tq did that one make?
TimeWarpF100
« Reply #12 on: May 13, 2015, 01:05:11 AM »
19 lbs on the truck headers
20 lbs on the stock 352 truck manifolds
48 lbs  C6AE-R Head
« Last Edit: May 13, 2015, 01:08:50 AM by TimeWarpF100 »
TimeWarpF100
« Reply #13 on: May 13, 2015, 01:11:12 AM »
24 lbs Performer 390
75 lbs Stock 352 Truck
GJCAT427
« Reply #14 on: May 13, 2015, 05:20:26 AM »
Now you need to weigh the cast shortie manifolds and a set of long cast headers, can you post a list of parts weights when your done?
