Author Topic: #8 Cylinder on my 390 is boogin' plugs  (Read 21881 times)
spork1o1
Re: #8 Cylinder on my 390 is boogin' plugs
« Reply #15 on: May 12, 2015, 08:04:41 AM »
If you have a PCV valve is it plumbed in to the intake runner for #8 cylinder?
amdscooter
« Reply #16 on: May 12, 2015, 11:02:26 PM »
Nope, be nice and easy if it were though.  ;)
NIsaacs
« Reply #17 on: May 14, 2015, 06:43:29 AM »
All Nick's gloom and doom aside. ::)
As Bob said, put a wrench on the intake bolts and snug them down and give it another try.
If it works great, if not it needed fixing anyways. ;)
The OP asked what "might" cause his plug issue, his issue "might" be what I said.....The "I hope it's not serious stuff was already covered"
Nick
2021 Ram 2500 4x4 Cummins of course!
2017 Ford Escape, 2.0 Eco Boost
2001 Ram 2500 4x4 QC short bed, Cummins, 6spd, some mods
1991 Dodge D250, reg cab, Cummins, 5spd, mods
1974 F-350, Cummins, 5spd, 3spd aux, mods
1975 F-250 4x4, 428, C-6, Sled Puller
amdscooter
« Reply #18 on: May 17, 2015, 04:43:39 PM »
So I put the rocker assembly back in, tossed the valve cover back on. Re-tightened all the intake bolts and tossed a spare plug from a previous tune up in #8. The plug on the left is what I used to get after 40 miles. The one on the right is what I pulled after 40 miles just minutes ago.
What can I say, you guys nailed it!  ;D Thank you everyone for your input!
 8)
« Reply #19 on: May 30, 2015, 05:24:42 PM »
FWIW, my then-new '64 427 was always harder on #8 plug than any of the others. And, when racing, we used-up plugs like peanuts. In the Thunderbolt, we only got one run on Champs. Luckily, they gave them to us by the case. But we'd get most of a day of runs if we used Autolites. We had to knock the porcelains out of the steel shells and give them back to get another case of the Autolites. But they worked enough better that the extra work was worth doing.
« Reply #20 on: May 30, 2015, 07:41:56 PM »
Are you running flat and lock washers on your intake?
Ford didn't, but I have found that a high quality flat and lock for each bolt, especially on alum intakes, holds their torque a lot better.
Also, the better the bolt, the better it seems to do, but be careful not to have too long or too short, easy to push or pull the threads out with the wrong length bolt
amdscooter
« Reply #21 on: May 30, 2015, 08:46:53 PM »
^^^ I'm using just flat washers with stainless bolts. I checked the lengths several times before choosing the final set, took me a few trips to the hardware store to ensure I had enough thread engagement w/o bottoming out in the bore. I think your lock washer idea is a winner, probably pick up a handful of splits this week. Driving her out to the Goodguys tomorrow.
« Reply #22 on: May 31, 2015, 05:47:23 AM »
I rarely disagree with Ross.  But this is one of those times.  The lock washer will not likely help.  Its not the bolt loosening up (assuming that that was the root cause) - its the gasket compressing and causing the bolt to lose it's crush/preload.  Same result - bolt gets loose - just a different cause.  Putting a wrench on those fasteners every so often is a perfectly good "cure" and you'll get a good results - especially if it has not been done for a long time since assembly.  But keep in mind that its not a forever cure.
Assuming a certain amount of torque or tightness applied to the intake bolts upon assembly, every time that intake expands and contracts from heat cycles it is going to try and move/bend.  The only part in the assembly that can accommodate this is the gasket face - so the gasket gets subjected to a fair amount of movement stress over time.  The standard Fel-Pro gasket like you have incorporates an embossed steel lined layer and can handle a great deal of movement and will still retorque nicely when it gets compressed as those embossments lose their shape.
Compare that to the paper with silicone bead Fel-Pro race gaskets, which initially seal well but are very unforgiving in terms of movement, tightness, and oil soaking.  On those, the silicone bead is less compressible than the paper base, so it embeds into the substrate acting like a "cutter" with each tightening or temperature cycle compression.  Couple that tendency with the FE oil soaked design that compromises the paper, and you have a recipe for the oft shown failures - and a gasket that can actually get worse with additional tightening.
If you are looking to the "right" way to design intake gasket interfaces you can check out how they do it on newer engines.  They'll use a sealing bead or o-ring inserted into a plastic or metal carrier.  The carrier will have hard stops for the fasteners to torque firmly against insuring that they stay tight and that compression of the sealing surface is as specified and is allowed to be separated from the tightening pressures.  Completely different sealing strategy.  I'll stick to my old stuff, but its good to see that they recognize and resolve the same problems at the OE level that we see in the driveway.
bartlett
« Reply #23 on: May 31, 2015, 06:46:05 AM »
I do the intake and Header bolts every spring 8) ...just snug them up ...
« Reply #24 on: May 31, 2015, 07:12:03 AM »
Barry raises a good and often not mentioned point. Many of today's engines, and engines for some years now, never leak oil due to the attention engineers have made to gaskets & sealing surfaces. Remember that many engines of the 50's, 60's and 70's leaked oil like a sieve and coated many a driveway!
