Author Topic: 67 Fairlane GTA  (Read 14440 times)
FordEver
67 Fairlane GTA
« on: May 09, 2015, 08:21:02 PM »
Performance Summary:
      1/4 mile ET: 10.584               1/4 mile MPH: 126.25
      1/8 mile ET:  6.710             1/8 mile MPH: 101.79
      60 foot time: 1.470
      Track: Joliet Ill  RT 66 Raceway, Fri night  5/23/15
      Weather Conditions:. cool, 70,s low hum, slight headwind, sunny
Vehicle Specifications: Original "S" code, C-6. 3.25L, Drk Grn, Blk Int, White Vinly roof, now all White Ext. Crites hood, fenders, trunk, bumpers/brackets. Mustang Buckets, 10 point Chrome Moly cage , frame tied.
Model Year: 1967
Model: Fairlane
Style: GTA
Engine Details (link to post in Dyno Results board if available: 10.5 cr, 427 Marine block, 482, Diamond flat, Scat "H" 4.25, Edelbrock, 2.15 I, 1.72 E, Port matched, bowl work/multiangle/unshrouded . Solid Comp. Erson RA, Trend PR, TW, 2- 750 VS Barry QF, CVR WP/Jay Brown adapter, Hooker 2" , Holley Fuel pump, reg. filters, 5 gal fuel cell
Transmission: C6 rolerized, Art Carr manual reverse VB, CJ Servo, PA Flexplate
Torque converter details (if automatic): JPT 8" 5k stall
Clutch details (if manual):
Driveshaft: Strange 3 ' steel
U-joints: 1350 Strange
Rear end type: 9" stock housing, reinforced perches
Differential type: Strange LW spool, Strange LW R+P, Alum big bearing pinion
Gear Ratio: 4.10
Axles: 31 spline Moser
Front tires: M/T 28 "
Front wheels: Vintage Wheel Works 4"X 15", American Style repo
Rear tires: M/T  # 3556  9"/29.5"
Rear wheels: Vintage Wheel Works 8"x15", 4 1/2 " B.S. American style repo
Front suspension information: Stock type, roller Spring lower mount, Cal Trac 90-10, Moroso Drag coil, lightest weight, no sway bar
Rear suspension information: Stock Type, Cal Trac Bars, Cal Trac shocks, Cal Trac single leaf, stock location.
Ready-to-race vehicle weight, including driver: 3400, no driver 3185
Chassis Dyno 10/21/15 Straightline Performance ,Joliet il
TQ 580@3800
HP 500@5800
af 11.4
http://www.autoimagery.com/gallery/v/2014/OE/BG/NSS/Bob+Mosher/IMG_1050.JPG.html
http://www.autoimagery.com/gallery/v/2014/OE/BG/NSS/Bob+Mosher/IMG_0793.JPG.html
R
« Last Edit: January 06, 2016, 10:50:55 PM by FordEver »
FordEver
Re: 67 Fairlane GTA
« Reply #1 on: May 24, 2015, 10:46:28 AM »
Updated performance numbers and vehicle weight. First good test on a good track this year,  the only upgrade/change from last years numbers were the installation of Jays water pump adapter and the CVR water pump and spall dual 11" fans, from a Edelbrock  w.p. and a semi flex fan. Before it was 10.675 @ 125.25, for a few years, now 10.584 @ 126.25. Seems to rev quicker, maybe some due to weather/ track, but stiil a good gain. Temperature control was right on.
« Last Edit: May 24, 2015, 11:02:21 AM by FordEver »
Re: 67 Fairlane GTA
« Reply #2 on: May 24, 2015, 04:10:30 PM »
According to the "dream wheel" (Moroso Power and Speed Calculator), that change in ET correlates to about 13-14 horsepower, which is probably what you picked up at the rear wheels with the water pump and fans.  Congrats on the improvement!
FordEver
Re: 67 Fairlane GTA
« Reply #3 on: October 25, 2015, 09:56:57 AM »
Told the dyno guy to stop at about 6k as I usually shift at 6k-6.3k .
Almost identical readings with the air filter on/off, I run the Blue Thunder 2 1/4 " 2x4 oval when racing
Re: 67 Fairlane GTA
« Reply #4 on: October 25, 2015, 11:06:15 AM »
Great times! Thanks for all the details, including the car weight w/wo driver. Love the Joliet track btw as it's built for both the fans and racers!
Re: 67 Fairlane GTA
« Reply #5 on: October 25, 2015, 08:46:33 PM »
What is the difference in horsepower from regular  dyno to chassis dyno or should I say what is the horsepower loss
FordEver
Re: 67 Fairlane GTA
« Reply #6 on: June 07, 2016, 07:26:10 PM »
Video off test/tune at Union  Grove Wi.
https://www.youtube.com/watch?v=pc_V5hC4Aew
edgarval
Re: 67 Fairlane GTA
« Reply #7 on: October 22, 2016, 12:24:07 PM »
Super nice !
machyoung
Re: 67 Fairlane GTA
« Reply #8 on: January 30, 2019, 11:01:35 PM »
Wow. That video makes my heart skip a beat.
6667fan
  • Every Second Counts
Re: 67 Fairlane GTA
« Reply #9 on: February 04, 2019, 02:12:05 PM »
That is good stuff. I quickly read the hp/ torque numbers and missed that they were rear wheel numbers until I went back. I’m thinking that car is fast for (only) 500 hp.
Using a conservative 15 per cent parasitic drivetrain loss the hp at the flywheel would be 575 and torque a healthy 667.
I gotta check out the build story on your engine.
Congrats,
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
