Author Topic: Lykins Motorsports 511 FE, 671 lb-ft of torque...  (Read 10689 times)
« on: May 09, 2015, 07:18:20 AM »
Performance Summary:
      Cubic Inches:   511            Dyno brand:  Stuska
      Power Adder:    N/A           Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  616
      Peak Torque:  671
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond aluminum, 4.310" bore
   Crankshaft brand, cast or forged, stroke, journal size:  RPM 4340, 4.375", .010/.010
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.700
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec 20cc dish, 10.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size: FM 146M10, FM 8-7200CH10, Durabond
   Piston rings brand, size, other notes:  Mahle 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  POP Blueprinted Melling HV
   Oil pan, windage tray, oil filter adapter:  Moroso T-sump
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams hydraulic roller, 251/257 @ .050", .635/.607" lift, 110/104
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Survival CNC heads
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI 2.250, 11/32
   Exhaust valve brand, head size, stem size:  SI 1.750, 11/32
   Valve springs brand, part number, specs:  Comp Cams 26055
   Retainers and locks brand, part number, specs:  Comp 703
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend 5/16, .080"
   Valve covers, brand, type:  Ford Racing
   Distributor brand, advance curve information:  MSD Pro Billet
   Harmonic balancer brand:  Powerbond SS
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information: Blue Thunder 1x4
   Carburetor(s) brand, type:  Quickfuel BDQ-850
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:54:54 PM by blykins »
Re: 511 FE, 671 lb-ft of torque...
« Reply #1 on: May 09, 2015, 07:42:00 AM »
Great torque number on that engine, Brent...
Yellow Truck
« Reply #2 on: May 09, 2015, 09:55:41 AM »
It would be very interesting to see the charts.
« Reply #3 on: May 09, 2015, 10:23:08 AM »
The graph shows a hp peak of 6000, but I think the graph indicates more of what happens through the entire run, even when the operator starts backing off the water valve (it's a Stuska).  I would go by the tabulated chart; I think it's more accurate in this case.  This is a little cooler water temp than what I usually run, we were previously hitting it at 170-180 degree water temp, but we had cooled the water back down right before this pull and just went ahead and ran it.
« Last Edit: May 09, 2015, 10:50:43 AM by blykins »
Yellow Truck
« Reply #4 on: May 10, 2015, 10:09:49 PM »
Remarkable torque curve. I've been reading about the influence of primary header diameter on peak torque RPM. Not sure I understand it, but curious what the header diameter was on that pull.
« Reply #5 on: June 25, 2015, 08:50:08 AM »
2"...
Joey120373
« Reply #6 on: January 17, 2017, 02:18:09 PM »
This is such a cool build, I'm very curious what the idle was like.
 RPM, it work ok with power brakes?
