Author Topic: Lykins Motorsports 427 Pond Block/Head Build  (Read 6708 times)
« on: May 07, 2015, 06:09:29 AM »
Performance Summary:
      Cubic Inches:   435            Dyno brand:  Stuska
      Power Adder:    N/A           Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  529
      Peak Torque:  552
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond cast iron, 4.280" bore
   Crankshaft brand, cast or forged, stroke, journal size:  $ crank, stock stroke .010/.010
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.490
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond, 10:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size: King MB5169HP010X/FM7170CH10/Durabond
   Piston rings brand, size, other notes:  Total Seal 1/16, 1/16, 3/16
   Oil Pump, pickup, and drive:  POP Blueprinted Melling HV
   Oil pan, windage tray, oil filter adapter:  Moroso T-sump
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullet solid flat tappet, 243/249 @ .050", .612/.614, 108/104 LSA
   Lifters brand, type:  Crower SBF EDM
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Pond aluminum, CNC
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI 2.250, 11/32
   Exhaust valve brand, head size, stem size:  SI 1.750, 11/32
   Valve springs brand, part number, specs:  Comp Cams 930, 154/380
   Retainers and locks brand, part number, specs:  Comp 741, Comp 630
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend 5/16, .080"
   Valve covers, brand, type:  Ford Racing
   Distributor brand, advance curve information:  MSD Pro Billet
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Performer RPM, port matched
   Carburetor(s) brand, type:  Holley 750
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:57:32 PM by blykins »
