Author Topic: Lykins Motorsports 428 Cobra Jet  (Read 7215 times)
« on: May 07, 2015, 06:03:22 AM »
Performance Summary:
      Cubic Inches:      433    Dyno brand:  Stuska
      Power Adder:    N/A       Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  422
      Peak Torque:  467
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 428 CJ, 4.165"
   Crankshaft brand, cast or forged, stroke, journal size:  Factory CJ
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.490
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul/Federal Mogul, Durabond
   Piston rings brand, size, other notes:  Total Seal, 1/16, 1/16, 3/16
   Oil Pump, pickup, and drive:  Melling HV
   Oil pan, windage tray, oil filter adapter:  CJ Repop, Ford windage tray, Ford CJ filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams hydraulic roller, 227/233 @ .050", 112/104, .583/.572
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Factory 427 CJ, no port work, valve job
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Ferrea, 3/8, 2.09
   Exhaust valve brand, head size, stem size:  Ferrea, 3/8, 1.65
   Valve springs brand, part number, specs:  Comp 914-16
   Retainers and locks brand, part number, specs:  Comp 741/609
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Harland Sharp
   Rocker shafts and stands, brand, material:  Harland Sharp
   Pushrods brand, type, length:  Trend 5/16, Ball/Cup
   Valve covers, brand, type:  Factory
   Distributor brand, advance curve information:  Factory, steel gear
   Harmonic balancer brand:  Factory repop
   Water pump brand, type (mechanical or electric):  Factory repop
   Intake manifold brand, material, porting information:  Factory cast iron, no port work, 78 lbs.......yep
   Carburetor(s) brand, type:  Holley
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:57:09 PM by blykins »
