Author Topic: Lykins Motorsports 496 FE  (Read 6866 times)
« on: May 07, 2015, 05:55:42 AM »
Performance Summary:
      Cubic Inches:    496      Dyno brand:  Stuska
      Power Adder:     N/A      Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  683
      Peak Torque:  600
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond aluminum, 4.310" bore
   Crankshaft brand, cast or forged, stroke, journal size:  Custom Scat Superlight, 4.250", 2.100" rod journal
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Oliver 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond forged, moly coated skirts, 11:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite coated, MS1010HXK, CB663HNXK, Durabond
   Piston rings brand, size, other notes:  Total Seal .043/.043/3mm
   Oil Pump, pickup, and drive:  POP Blueprinted Melling HV
   Oil pan, windage tray, oil filter adapter:  Aviaid
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams solid roller, 270/280 @ .050", .438/.436 lobe lift, 112/106
   Lifters brand, type:  Crower bushed
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  KC Stage 3 Edelbrock
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Custom Ferrea 5/16 stem, 2.250"
   Exhaust valve brand, head size, stem size:  Custom Ferrea 5/16 stem, 1.76
   Valve springs brand, part number, specs:  PAC 1299, 285/720
   Retainers and locks brand, part number, specs:  Comp 733, 610
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D Race
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend 7/16 double taper
   Valve covers, brand, type:  Blue Thunder
   Distributor brand, advance curve information:  MSD Pro Billet
   Harmonic balancer brand:  ATI
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Dove  Tunnel Wedge
   Carburetor(s) brand, type:  Quickfuel
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:58:00 PM by blykins »
