Author Topic: Lykins Motorsports 445FE  (Read 14794 times)
« on: May 07, 2015, 05:47:55 AM »
Performance Summary:
      Cubic Inches:    445     Dyno brand:  Stuska
      Power Adder:     N/A    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  525
      Peak Torque:  588
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 390 block, 4.080"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 9000, 4.250"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.700
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged, 10:1 SCR
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  FM 125M, Clevite 743, Durabond
   Piston rings brand, size, other notes:  Mahle 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling HV
   Oil pan, windage tray, oil filter adapter:  Moroso T-Sump, factory CJ adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams hydraulic roller, 235/241 @ .050", .613/.576, 110/104
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Ford Racing, factory
   Cylinder heads brand, material, port and chamber information:  Survival Motorsports, as-cast
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  REV 2.200
   Exhaust valve brand, head size, stem size:  REV 1.65
   Valve springs brand, part number, specs:  Comp 930, 145/360
   Retainers and locks brand, part number, specs:  Comp 741, 630
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend, 5/16 .080"
   Valve covers, brand, type:  Ford Racing
   Distributor brand, advance curve information:  MSD Pro Billet
   Harmonic balancer brand:  Powerbond street
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Edelbrock Performer RPM, no port work
   Carburetor(s) brand, type:  Quick Fuel HR-750
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:52:43 PM by blykins »
427HISS
Re: 445FE
« Reply #1 on: June 24, 2016, 08:56:31 AM »
Great street engine Brent.
What's the apx cost ?
Re: 445FE
« Reply #2 on: June 28, 2016, 05:06:20 AM »
That one was $12480.
120mm
Re: 445FE
« Reply #3 on: March 26, 2017, 11:34:57 AM »
Brent,
If you may; can you discuss why Quickfuel 750, instead of an 850 cfm carb on that particular combo?
Thanks!
Re: 445FE
« Reply #4 on: March 26, 2017, 12:09:06 PM »
If someone wants a brand new carburetor, Quick Fuel is my choice.
The HR series can be had in both mechanical and vacuum secondaries and with a choke, which matches the degree of streetability that some guys want.
Used Holleys can be rebuilt cheaply.
Re: 445FE
« Reply #5 on: March 26, 2017, 12:22:46 PM »
This looks like a driver, I'd suspect the 750 is just as good as an 850 in the under street rpm range.
Having owned both of each, I have to say, old Holley's are nice, but the new features of QF carbs and the quality of the metal used makes them much more fun to work with.  I don't think I'd ever buy a new carb that wasn't a QF.
120mm
Re: 445FE
« Reply #6 on: March 26, 2017, 10:41:05 PM »
Cool. Thanks! Though 525/588 is awful nice "street" for this combo. :)
Thanks, Brent!
WerbyFord
Re: 445FE
« Reply #7 on: December 14, 2018, 11:50:19 PM »
Brent do you have a graph of this one?
I'm having trouble getting near 588 ftlb out of the Gonkulator.
Was it 10.0 CR or maybe higher?
Re: 445FE
« Reply #8 on: December 15, 2018, 05:32:53 AM »
It was 10:1.
However, the peak torque could have been the way the dyno was loaded or something similar.
I do know that the owner put it on a chassis dyno to tune it in CA and it put down over 500 lb-ft to the tires, going through a TKO 600 and a 9" Ford.
But dynos are dynos are dynos.....................................I really don't pay attention to any of them anymore unless it's multiple engines on the same dyno, where you can see what was done incrementally, etc.
