Author Topic: Lykins Motorsports 465 inch Tunnel Port  (Read 6971 times)
« on: May 07, 2015, 05:41:38 AM »
Performance Summary:
      Cubic Inches:     465     Dyno brand:  Stuska
      Power Adder:      N/A    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  696
      Peak Torque:  588
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond cast iron, 4.310"
   Crankshaft brand, cast or forged, stroke, journal size:  RPM 4340, 3.980", 2.750"/2.200"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Lunati 6.800 H-Beam
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged dome, 12:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  King/Federal Mogul/Durabond
   Piston rings brand, size, other notes:  Mahle, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  POP HV Melling
   Oil pan, windage tray, oil filter adapter:  Moroso Road Race, billet filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams solid roller, 260/270 @ .050", .760" gross lift, 108/104
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Factory TP, ported by Lawes Mayfield
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Ferrea hollow stem, 2.250", 11/32
   Exhaust valve brand, head size, stem size:  Ferrea 1.750", 11/32
   Valve springs brand, part number, specs:  PAC, 280 seat 660 open
   Retainers and locks brand, part number, specs:  PAC titanium, Comp locks
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street, 1.76
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend 5/16" .105"
   Valve covers, brand, type:  Blue Thunder/Holman Moody
   Distributor brand, advance curve information:  MSD Pro Billet, locked out
   Harmonic balancer brand:  Powerbond SS
   Water pump brand, type (mechanical or electric):  CSR electric, Jay Brown adapter
   Intake manifold brand, material, porting information:  Factory 2x4 TP, ported by Lawes Mayfield
   Carburetor(s) brand, type:  (2) Quick Fuel 725's.
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:58:25 PM by blykins »
