Author Topic: Lykins Motorsports 427 S/O, LR 2x4  (Read 6721 times)
« on: May 07, 2015, 05:34:38 AM »
Performance Summary:
      Cubic Inches:   429       Dyno brand:  Stuska
      Power Adder:   N/A        Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  510
      Peak Torque:  511
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 S/O.  4.250" bore
   Crankshaft brand, cast or forged, stroke, journal size:  Factory $ crankshaft, stock stroke, 2.750"/2.200"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Oliver, 6.800"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec, 11.5:1, 4cc Dome, .043/.043/3mm
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  King main/rod, FM cam
   Piston rings brand, size, other notes:  JE
   Oil Pump, pickup, and drive:  Precision Oil Pumps Melling HV
   Oil pan, windage tray, oil filter adapter:  Moroso Road Race
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullet solid flat tappet, 255/263 @ .050", .640" gross lift, 106/104
   Lifters brand, type:  Crower SBF EDM
   Timing chain and timing cover:  Ford Racing/factory
   Cylinder heads brand, material, port and chamber information:  Lawes Mayfield ported C3 LR
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Ferrea hollow stem, 2.150" x 3/8
   Exhaust valve brand, head size, stem size:  Ferrea hollow stem, 1.750" x 3/8
   Valve springs brand, part number, specs:  PAC 1294, 160/425
   Retainers and locks brand, part number, specs:  Comp 741, Comp 609
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  POP factory-ish adjustable
   Rocker shafts and stands, brand, material:  POP
   Pushrods brand, type, length:  Trend, 5/16" .105",
   Valve covers, brand, type:  Custom Lykins Motorsports
   Distributor brand, advance curve information:  Mallory dual point
   Harmonic balancer brand:  Romac
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Lawes Mayfield ported C3 2x4
   Carburetor(s) brand, type:  Quick Fuel
   Exhaust manifolds or headers brand, type: 2" headers
« Last Edit: August 16, 2020, 05:56:41 PM by blykins »
Re: 427 S/O, LR 2x4
« Reply #1 on: May 09, 2015, 10:24:07 AM »
Interesting comparison to my MR 427.
One full point of compression more, very similar cam duration but with .080 more lift. Ported Low Riser heads vs. my stock Medium Riser heads.
+14hp and +27tq with a little more lift and compression compared to mine. Pretty much as you would expect.
Re: 427 S/O, LR 2x4
« Reply #2 on: May 09, 2015, 10:55:27 AM »
If I recall correctly, this one carried the 510 hp all the way to 6500, which is what I was wanting since it's for an FIA road race Galaxie.  Rules dictated a lot of parts we had to use.
I think the heads came out at around 270-280 cfm.
