Author Topic: What hone grit for moly rings?...  (Read 5662 times)
« on: May 06, 2015, 10:20:25 AM »
I'm wondering what the latest thinking is on hone grits for different types of rings used. I'll be replacing the rings in my 390 with moly faced rings since it'll be a heavy load hauler and I need to get a new hone. My old stones are wore out, but since my bores are not fresh, I'll probably use a dingle berry hone.
Re: What hone grit for moly rings?...
« Reply #1 on: May 13, 2015, 12:10:44 PM »
Check with the ring manufacturer.  It seems to run from 220 to 400.  I use a 320 hone and just split the middle.
« Reply #3 on: May 13, 2015, 11:05:04 PM »
That's what I was going to do, check with the ring maker.
Thanks for the link, Bob. That's an interesting article.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #4 on: May 17, 2015, 09:32:26 AM »
That is your best bet! Always check with the ring manufacturer. They would tell you.... JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
