Author Topic: FE Dyno Results and Engine Information  (Read 31106 times)
« on: May 05, 2015, 02:45:12 PM »
This board is for posting information on the dyno results you have for your FE engine.  I have put a suggested format below, and put a couple of example engines on the board to start with.  You can copy the format from this sticky, and paste it into your post, and then fill in the information.  If you don't have all the info (very few people will), don't sweat it, just fill in what you have.  If you have a photo of the engine, either on or off the dyno, please post that also.  Comments always welcome.  Hopefully this board will turn into a useful repository of FE engine data.
Performance Summary:
      Cubic Inches:               Dyno brand:
      Power Adder:               Where dynoed:
      Peak Horsepower:
      Peak Torque:
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:
   Crankshaft brand, cast or forged, stroke, journal size:
   Connecting Rods brand, material, center to center distance, end sizes, bolts:
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
   Piston rings brand, size, other notes:
   Oil Pump, pickup, and drive:
   Oil pan, windage tray, oil filter adapter:
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050")
   Lifters brand, type:
   Timing chain and timing cover:
   Cylinder heads brand, material, port and chamber information:
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:
   Exhaust valve brand, head size, stem size:
   Valve springs brand, part number, specs:
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:
   Valve covers, brand, type:
   Distributor brand, advance curve information:
   Harmonic balancer brand:
   Water pump brand, type (mechanical or electric):
   Intake manifold brand, material, porting information:
   Carburetor(s) brand, type
   Exhaust manifolds or headers brand, type:
« Last Edit: May 20, 2015, 03:49:57 PM by jayb »
Mike Caruso
  • 6250
Re: FE Dyno Results and Engine Information
« Reply #1 on: March 26, 2016, 01:29:21 PM »
Jay,  ;D
Great Idea one place for all to go and do their own digging. This will save a lot a questions asked in Forums. Sure there will still be questions but at higher level. Again Great job. Happy Easter
Mike
Mike Caruso
Do It Like You Mean It .....or Don't Bother!
www.AERA.org
Engine Professional Magazine Free To All
