Author Topic: Original WAC aluintake  (Read 3999 times)
« on: April 27, 2015, 01:47:32 PM »
I was at the shop of the guy who is porting my heads
and there was a 390 from a 64 Galaxie with a Ford
alu.intake C3AE xxxx WAC. What kind of intake is that?
Single fourbarrel and werry light for a FE intake.
 Much lighter than my streetmaster
Re: Original WAC aluintake
« Reply #1 on: April 27, 2015, 02:49:20 PM »
I'm not familiar with that one, unless its the later version of the standard aluminum low riser intake that came out in 1961.  Do you have a picture?
« Reply #2 on: April 27, 2015, 03:06:09 PM »
No pic had no phone or camera with me. The WAC was not cast but stamped
no casting numbers on top of the intake just a oval with fomoco and
fireing order with small digits and numbers.
The C3....castingnr was under the intake. Singel4 barrel, the runners
matched my Cobrajet gaskets, no date codes,the block is same casting
numbers as my PI block with nubs for crossbolting but not machined
drilled for hydraulic lifters so no PI.
But if its alu its some kind of hiperf intake right?
Gues i must go there with a camera the owner is from my small town but
i have never seen or heard of him
Dual plane intake with four holes i may ad
« Last Edit: April 27, 2015, 03:12:41 PM by Heo »
