Author Topic: Identify this timing cover?  (Read 8039 times)
Jackal
« on: March 26, 2015, 10:56:06 AM »
Supposedly on a 428CJ from '67. Supposedly also a factory race engine. Just curious, apparently no one seems to have an answer for that strange "hump" in it, or what may lie behind. I'm told that the casting number behind the generator shows that it is a 406/428, and that the trans had to be dropped to check for the presence of an "A" on the back of the block indicating that it is the 428. There may or may not be some other special markings stamped down near or under the oil pan. ;) Thanks!
« Last Edit: March 26, 2015, 10:59:59 AM by Jackal »
Re: Identify this timing cover?
« Reply #1 on: March 26, 2015, 11:24:25 AM »
That is an early stamped steel timing cover, 1958 through 1961 FE I believe.  I'm not sure why the hump is there, but I would guess that the early fuel pumps required it.  Here's a cleaned up one on ebay:
http://www.ebay.com/itm/1958-1959-1960-1961-Ford-332-352-390-FE-Timing-Chain-Cover-/191537899334?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c988c6746&vxp=mtr
Also, no such thing as a 67 428CJ; those engines started midway through the 1968 model year.
Jackal
« Reply #2 on: March 26, 2015, 01:08:13 PM »
Wow thanks for the quick info Jay! Bonus points for the current link to the same cover...especially a freshly blasted one. ;) Love that '64 Gal. Looking for a 63.5 XL myself.
« Last Edit: March 26, 2015, 01:20:22 PM by Jackal »
fairlanegt427
« Reply #3 on: March 27, 2015, 04:53:22 PM »
I have been around the fe for a long time now.  I have never seen one of those.   but like jay says its got to be for a different style of fuel pump.
Qikbbstang
« Reply #4 on: March 27, 2015, 07:54:12 PM »
I have one, they're definitely cool with plenty of complex features that had to be complex/costly for FoMoCo to manufacture. Never scale'd one up against a cast alum one but they are not heavy.
TorinoBP88
« Reply #5 on: April 02, 2015, 12:56:57 AM »
I have one too, mine is from a 1958 352,  Its a shade heavier then aluminum, but not much.  It looks really period correct with baldy covers.
« Reply #6 on: April 02, 2015, 01:14:58 AM »
Yes it is an early stamped steel timing cover, looks just like the one on my origional 1959 332 FE. As mentioned, the bulge is for the mechanical fuel pump. These were used with the early style flanged camshaft with the spring and button that rode against the inside of the cover.
« Reply #7 on: April 05, 2015, 11:47:33 AM »
58-60 i think. My 61 uses the newfangled aluminum cover.
fe66comet
« Reply #8 on: April 05, 2015, 12:08:43 PM »
I have seen funky stuff like that.on industrial and boat engines.
gdaddy01
« Reply #9 on: April 12, 2015, 11:04:24 AM »
make sure to use the early gasket to seal it to the block , it will leak if you do not . I learned the hard way .
