Author Topic: Oil additives explained.  (Read 4468 times)
Yellow Truck
« on: March 18, 2015, 11:51:01 AM »
A little more technical than we normally get into, but they had a bigger budget than most engine builders.
http://www.sciencedaily.com/releases/2015/03/150313130937.htm
Qikbbstang
Re: Oil additives explained.
« Reply #1 on: April 09, 2015, 11:32:53 AM »
Obviously the engineers at the big-oil companies have a stake in the results but they say "buy the oil intended for the job" and skip the additives. Had a friend that owned a solvent and oil business with the weighted bearing test rig that could leave the bearing surfaces scored and smoking and no question his additive of choice {Power Up} was really impressive at increasing the load carrying capacity of any oil you selected to "Power Up". But then you hear some of those additives are chlorine based (rub a dilute chlorine mix between your fingers--it's slick) .  Remember the shysters draining the oil out of cars and later when they were selling wax's toughness by lighting the surface of a R/R's hood on fire with a flammable fluid   ?
« Last Edit: April 23, 2015, 10:58:26 AM by Qikbbstang »
Qikbbstang
« Reply #2 on: April 23, 2015, 11:09:40 AM »
Link to great thread on additives. Anyone get the feeling you could be dealing with the devil?;
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1669302
