Author Topic: Max tire/wheel size for 69 Mach 1  (Read 28339 times)
bw_kc
« on: December 27, 2011, 11:21:44 PM »
Want to stay with Magnum 500 style 15" wheels.  What is the max wheel size/offset i can install?  Hoping to install drag radials or MT E/T Streets.
Car is 69 Mach1
rcodecj
Re: Max tire/wheel size for 69 Mach 1
« Reply #1 on: December 28, 2011, 10:09:37 AM »
If you are willing to massage the front of the inner wheel well you can fit quite a bit, if not then that is the first clearance obstacle you will encounter.
I have ran 8" with 5.5" backspacing on a 275/60/15 and 10" with 5.5 backspacing with a 275/50/15 on my 69 mach1. The 10" could have had more backspacing, if I recall correctly 6" on the 10" rim would have cleared. I also run a 9" rim with 5.5" bs with a 275/60/15 on my 67 but ended up rolling the outer fenderwells for a bit more safety, it was close as that car is really low. I have ran a 27/10.50/15 Mickey Thompson ET street on my 67 on the 10" 5.5 bs rims but only at the track. I run as close as 1/4" clearance to the leaf spring with no problems, some people would not be comfortable with that.
Maybe Jay will chime in, I think his magnum 500's were custom backspacing and he came up with something around 6"-6.25" on a 10".
« Reply #2 on: December 28, 2011, 10:36:44 AM »
I agree with the above, have 8" rear rims with a similar size tire, but 16". The front inner corner of the w/wheel does need trimming as does sometimes the rebound bumper sheetmetal (12 o'clock high, above the axle centerline). Once past that the leaf spring clearance is the issue. I'd also run that 1/4" minimal clearance as mentioned but only on a drag car not seeing regular and tight turns. A streeter would need more to prevent sidewall rash.
rcodecj
« Reply #3 on: December 28, 2011, 10:59:40 AM »
Good catch machoneman on the rebound bumper trimming. I trimmed it on my 67 but refuse to touch it on my 69.
9" Prostar, 5.5bs, 275/60/15 BFG drag radial
« Last Edit: December 28, 2011, 11:03:03 AM by rcodecj »
« Reply #4 on: December 28, 2011, 11:07:09 AM »
There is also a great link below (Ford Muscle but it links to the Classic Mustangs Forum) for '69-'70 Mustangs. I can't say these are the absolute maximums but the chart does cover a range of tires sizes and diameters.
http://www.fordmuscleforums.com/mustang-pages-1965-1973/501463-max-wheel-size-69-mustang.html
rcodecj
Prostars, 15by8 5.5bs 275/60/15
« Reply #5 on: December 28, 2011, 11:12:58 AM »
rcodecj
Prostars, 15by10, 5.5bs, 275/50/15
« Reply #6 on: December 28, 2011, 11:18:41 AM »
Dodgestang's detailed wheel spacing, size charts for Mustangs
« Reply #7 on: December 28, 2011, 11:19:28 AM »
Gee, I should have just posted Dodgestang's website in my previous post!
http://www.dodgestang.com/mustang.htm
Nice pics too rcodecj.  Great car and a good looking stance as well.
rcodecj
MT ET Street 27/10.50/15 on 10" rim, 5.5bs
« Reply #8 on: December 28, 2011, 11:30:29 AM »
« Reply #9 on: December 28, 2011, 11:57:46 AM »
I was going to chime in here but I think you guys have got it covered.  My 15X10s with a custom 6.5" backspacing didn't work with the tires I chose; section width of the tires was too big, and I ended up barely rubbing on both the leaf spring and the inner wheel lip.  This was after fairly extensive trimming of the wheel lip, bump stop bracket, etc.
From a drag tire perspective, I ran 10.50s and 10.60s on 15X8 magnums with the 4.5" backspacing, and 27" tall 9" wide M/T slicks.  This was with Cal Tracs, their monoleaf springs, and Ranch adjustable rear shocks, and a 4500 converter.  The car hooked like nobody's business with that setup, and if I hadn't gone with the supercharged engine later I'd probably still be running that combination.  If you've got the front and rear suspension worked out, you can do pretty well on a 9" slick.
« Reply #10 on: December 28, 2011, 12:18:04 PM »
Yes, section width is often the one aspect that can bite you and cause rubbing, or worse, where one might not expect it. Even though the tire maker's list section widths (one sometimes has to hunt for this dimension btw) for each tire, one can't assume that section widths are identical for the exact same tire size between two makers. A 275/60/15 Goodyear tire does differ from the same size TA, M/T tire, etc.
rcodecj
« Reply #11 on: December 28, 2011, 01:10:45 PM »
Jay,
Can you post the part number of the M/T slick that you ran?
I haven't been able to find a 27" tall slick at 9" wide.
http://www.mickeythompsontires.com/strip.php?item=ETDrag
« Reply #12 on: December 28, 2011, 01:49:25 PM »
It's the 3054.  It's officially a 28" diameter tire, but if you look at the specs the actual diameter is 27.3".
rcodecj
« Reply #13 on: December 28, 2011, 02:40:24 PM »
That's the same exact slick that Jason Moulton from Mickey Thompson recommended for my 67 mustang.
afret
« Reply #14 on: December 28, 2011, 05:56:18 PM »
Have M/T 275/60-15 ET Street Radials on 15x10 wheels with 6.125 BS.  The tires are 12" section width on these wheels.   Went to disc brakes which pushes the wheel out about 1/8" compared to the drums so could go to 6.25" BS now.
