Author Topic: Sonic Check  (Read 14842 times)
67GT500
Sonic Check
« on: February 23, 2015, 12:41:31 AM »
Hi, just had my 428 sonic checked.. a little unsure if it would be ok for a rebuild.. it currently is standard bore.. Engine builder says it has bad core shift and to look for another block.. Any advice would be great
Re: Sonic Check
« Reply #1 on: February 23, 2015, 01:04:47 AM »
Depending on how much the bores needed to clean up, I'd use it. Often times, your average machinists are only thinking in typical .030 overbores and don't realize, or have experience in,  doing minimal overbores and using custom sized pistons to save an older block. Since custom pistons are easily gotten, it's much wiser to go that route than standard aftermarket slugs in standard overbores. You can get alot more use out of a block than just boring away like they did in the old days. FEs are notorious for thin walls and core shift, so minimal overbores and custom pistons is really the only smart choice, in my opinion. That block is certainly useable for any street build.
Re: Sonic Check
« Reply #2 on: February 23, 2015, 07:48:04 AM »
I agree with what Doug said and will add that a shop with the proper equipment can also offset bore the individual cylinders using the sonic map to either even out the wall thickness or bias the thickness to the thrust side as needed. And also like Doug said, what are your plans when done, street build or race engine? Is it the original block for the vehicle with matching date codes and possibly a partial VIN?
Re: Sonic Check
« Reply #3 on: February 23, 2015, 08:24:10 AM »
If accurate - those numbers are NOT thin by 428 standards.
That is a good buildable block.
KMcCullah
Re: Sonic Check
« Reply #4 on: February 23, 2015, 11:08:20 AM »
Looks good to me. I'd build it. Even with the core shift shown on the sonic, at .030 over your thinnest spots still would be around .100.
Call Blair maybe he still has some of these trick CP 428 .015 pistons.
http://fepower.net/simplemachinesforum/index.php?topic=745.0
Kevin McCullah
Re: Sonic Check
« Reply #5 on: February 23, 2015, 12:01:00 PM »
I'd build it too, but it would be worth minimizing the overbore, and going to a custom piston if that was necessary.  Assuming here that you are looking at up to 600 HP; anything over that would be questionable, in my opinion...
67GT500
Re: Sonic Check
« Reply #6 on: February 23, 2015, 01:13:56 PM »
Thanks for the comments.. I'm not looking at going big on HP, around 450. Edelbrock heads, FPA headers and a cam, which i haven't picked yet.. so this is some good news that the block is ok to use. Its not a matching numbers block, just a replacement block that i had been saving for a rebuild, so to get the news that it had bad core shift and that the recommendation was to look for another block, was a bit of a let down..
I will take the advice and look at some custom pistons
Re: Sonic Check
« Reply #7 on: February 23, 2015, 01:22:31 PM »
And maybe a different builder?
He may be lacking the knowledge to build 428.
Re: Sonic Check
« Reply #8 on: February 23, 2015, 01:39:40 PM »
Howie has a valid point. If the guy acts like it's a stupid idea or scoffs at it, I'd walk away and find someone else.
67GT500
Re: Sonic Check
« Reply #9 on: February 23, 2015, 02:18:01 PM »
I think he might just be leaning on the "safety advice" side. by providing the sonic check sheet, then leaving the decision up to me.
Re: Sonic Check
« Reply #10 on: February 23, 2015, 03:20:53 PM »
I think what the guys are saying is that even though he may be a great builder, if he knew FEs well, he would be aware that those numbers are pretty safe.
In other words, he wouldn't be giving you the choice to build or not. He would say that those are pretty good FE numbers and there are plenty running around now with numbers not as good (like mine). Now here is what I suggest you think about for this block. Or, here is what I would do with this block.
Get the difference? :)
RobMcQ
Re: Sonic Check
« Reply #11 on: February 24, 2015, 01:57:36 AM »
Yep, that is a bad sonic test, particularly if you're not used to looking at FE block sonic tests. For an FE block, it's not too unusual though. Not a problem with a good offset bore job and some semi-custom pistons, as has been pointed out here.
Offset boring though may not be nearly as simple as it sounds. The machine shop has to have the right equipment. Many shops are still using old style, three finger air lock boring bars like a Rottler F2, or a Kwick-Way, etc. While the machine shop will tell you they can offset bore a block with these, they really can't, no mater what the machinist believes. He can be very careful in setting up the boring bar, but when you release the air lock, those fingers will move the bar "just a little bit". It's just not possible to be highly accurate with these machines, and there is no way for the machinist to verify the accuracy. Nor can they be used to repeat a cut in the same bore, say doing a small initial cut, then a slightly larger one. They are simply not accurate enough to do so.
To accurately bore a block, a CNC controlled boring bar is needed. It doesn't have to be the latest and greatest 5 axis CNC Multi-purpose machine, an older Rottler CNC F5 can do the job. You can check out YouTube for videos of an F5, or a Rottler F69, an RMC V30, a Centroid, etc., to get an idea of the differences. Not only can you set a CNC bar to offset the bore any amount you desire, but you can use it to creep up on a minimum oversize bore as well. For example, wear ridges are typically heavier to one side of the bore. If you bore the cylinder on center, it may easily take .030" or more to clean the cylinder. But, if you offset the bore center towards the worst part of the ridge by say .005", and then do a small .010" first cut, you can evaluate the result, and maybe make a small correction on a next cut. We've often been able to keep a badly worn block at only a .030" oversize , when other shops have said they had to go .040" or .060" in order to clean the bore.  For their old style equipment, they are probably right.
So when talking to a machine shop about offset boring your block, find out what type of equipment they are using. You don't need to question their abilities, or denigrate their equipment, but simply inform yourself as to their capabilities so that you can make an informed decision.
Rob McQuarie
Blue Oval Performance
Re: Sonic Check
« Reply #12 on: February 24, 2015, 08:42:31 AM »
Rob I'm curious what made you talk about offset boring.
Was it in the numbers or the core shift comments. Or....
Just trying to learn. :)
Re: Sonic Check
« Reply #13 on: February 24, 2015, 09:54:09 AM »
That's good info, Rob. Thanks for the education.
Bolted to Floor
Re: Sonic Check
« Reply #14 on: February 24, 2015, 09:57:29 AM »
For the uneducated like me, can someone explain the test result sheet? What I get out of is 8 readings per hole. If your bore it .030 then you loose .015 from each of those numbers. Front and back seem right for location in cylinder, but major / minor makes no sense to me.   ???
