Author Topic: 418  (Read 8966 times)
TimeWarpF100
« on: February 03, 2015, 07:09:13 PM »
n/m
« Last Edit: March 13, 2015, 08:44:27 AM by TimeWarpF100 »
Re: Piston availability for .040 410
« Reply #1 on: February 04, 2015, 08:15:59 AM »
Barry, Blair, or I can get you some forged pistons for way under $720.
Cast isn't bad, would be a cheap route if you're just wanting something to play with and sell down the road.  However, most compression heights of out-of-the-box cast pistons really don't lend themselves to good quench numbers.
« Reply #2 on: February 04, 2015, 08:30:24 AM »
Cast is fine in a daily driver type cruiser.
Considering every production 390 came with a cast piston.
When to step up to forged. Always a good question.
I think it is a cost vs reward thing.
JamesonRacing
« Reply #3 on: February 04, 2015, 03:52:00 PM »
Wouldn't these work for a 40-over 410?
http://www.summitracing.com/parts/slp-381np40/applications/make/ford?prefilter=1
Looks like the compression height is a good fit.
« Reply #4 on: February 04, 2015, 05:02:16 PM »
Looks good to me, I'd run them.  However, if you aren't going to keep the motor, maybe build it as a 390 and keep or sell the crank?
TimeWarpF100
« Reply #5 on: February 04, 2015, 06:40:26 PM »
Sending you a PM
TimeWarpF100
« Reply #6 on: February 04, 2015, 06:49:52 PM »
n/m
« Last Edit: March 13, 2015, 08:44:52 AM by TimeWarpF100 »
MeanGene
« Reply #7 on: February 05, 2015, 09:02:08 PM »
Might be cheaper to just get another 390 block, cast .030 390 pickup (410 car) pistons are cheeep
TimeWarpF100
Re: How to fix a "Oil Leak" BBM 418
« Reply #8 on: March 09, 2015, 07:55:24 PM »
n/m
« Last Edit: March 13, 2015, 08:45:16 AM by TimeWarpF100 »
