Author Topic: what size Holley jet to use as a oil restricter  (Read 4561 times)
jholmes217
« on: February 01, 2015, 02:46:22 PM »
What size Holley jet should I use for oil restriction in iron 428 Cobra Jet heads using a flat tappet hydraulic cam?  I am using Precision Oil Pumps roller tip rockers and stands with the stock oil return tins.
« Last Edit: February 01, 2015, 03:06:28 PM by jholmes217 »
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
Re: what size Holley jet to use as a oil restricter
« Reply #1 on: February 01, 2015, 03:34:08 PM »
I use #70 jets for that, but I know that some people use up to #90.
jholmes217
« Reply #2 on: February 02, 2015, 12:01:14 AM »
Thanks Jay.  I see now where it says that in your book when you were describing the dyno mules.
Jeff
Olympia WA. area
